I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
    Master:
  • 478 Answers
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Posted on Nov 11, 2014
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
  • 86 Answers
SOURCE: My Hotpoint Ultima super silent is occasionally
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Posted on Jul 08, 2009
barkencoa
  • 3463 Answers
SOURCE: can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Posted on Aug 14, 2010
  • 389 Answers
SOURCE: hotpoint ultima super silent wf 860 draw opening on spin
could be uneven but could allso be door catch not locking properly or needs adjusting
Posted on Nov 02, 2011
  • 389 Answers
SOURCE: HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
fault code 03 means that it could not complete the final spin ie the balance censor or fab conditioner valve did not open try leveling it it could do the trick
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Wf 865 water does not seem to be heating up
The cycle does not advance because the temp sensor does not detect enough temperature.
The heating element must be tested using a multimeter , and eventually replaced.
Usually the element is the problem, if element is fine, the temp sensor and the timer control must be checked.
Apr 16, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima super silent wash wt 960
i rang the service engineer and they looked up the code, it was something to do with overheating, they are sending someone to fix it soon!
Dec 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
