I have a lg 47ls4600 led tv it has no Picture when I power it on but the red power light blinks 3 time. I got a paper supply from shopjimmy.com but it still doing the same thing can you help thank you
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Nov 12, 2014
5 Suggested Answers
roety
  • 585 Answers
SOURCE: Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Posted on Aug 17, 2009
freetek
  • 5568 Answers
SOURCE: tv will not power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Mar 30, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
archaeology
  • 662 Answers
SOURCE: i replaced three cans. they were bulged on the
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Posted on Mar 24, 2011
How Do I repair my LG LED TV that does not power on?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
You can repair it very easily, within seconds.
Sep 16, 2015 | LG Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
TV philips 29PT8520 there is no picture. First led lamp of 3 blinks red then off and then blinks 7 times and it repets... can you help what went wrong?
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem...
Aug 06, 2011 | Televison & Video
Black Screen no sound, Green light blinks for some time then goes red then recycles back to green
Tv have power LED lights indication are blinking and recycle blinking.Mean the tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 02, 2011 | Sony KDS-R50XBR1 50" HDTV
My tv comes on just fine witout a picture and is blinking a red light code of 5 blinks. any suggestions on what it could be?
Tv power LED light indication on the front panel of the screen power LED light is flashing?Yes,the power supply board have problems,it dying.That board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 08, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
How to fix continous red blinking lights
Ur power board supply is dead.Replaced the power supply well solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 11, 2010 | LG 26LX1D 26 in. LCD HDTV
No picture on LG Flat panel and no sound. Only
know how to sloder?Replaced parts like capacitors burst open or puff up in the power supply.Or replaced the whole refurbish power supply board.Shopjimmy.com,Ebay.com to buy.
Jan 14, 2010 | LG 27LC2R 27 in. LCD TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
