Question about Crafts & Hobbies
The Lionel lines train is going too slow and it
The Lionel lines train is going too slow and it won't go up by itself. How am I ever going to the the train go fast and go up by itself?
    Problem Solver:
  • 5 Answers
Try replacing your power source, the old coils may be burned out over a period of time, or check voltage on the output side!
Posted on Nov 12, 2014
5 Suggested Answers
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
TKahill
  • 89 Answers
SOURCE: I have a Lionel War
From the impact of the train when it hit the ground, it has probably damaged the sound system beyond repair. There are multiple problems that could've occurred, such as the wires breaking/loosening, or the sound box could have broken. There isn't a realistic way to fix this, really.
Even though it may not have been your fault, you should try to prevent things like this from happening in the future.
As to the 042 switches, this is likely the same problem. You can order replacement switches online to test them and make sure for relatively cheap, however.
There is hope for you, however. Go to the link below to go to Lionel's customer service page. There, you can find replacement parts and service stations that can replace/repair your train for you, for a small price compared to the value of the train itself. Good luck getting it fixed!
http://www.lionel.com/CustomerService/
Posted on May 03, 2011
  • 35 Answers
SOURCE: Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Posted on Dec 16, 2011
time to clean & lube your train & track.
here's a couple link's that should help :
Maintaining Your Lionel Trains
Cleaning Track
Nov 11, 2014 | Crafts & Hobbies
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Looking for instructions for lionel fast track automatic switch
Try contacting the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Oct 12, 2013 | Crafts & Hobbies
I HAVE A LIONEL 2-4-2 POSTWAR WITH SLOW SPEEDS. ANYONEHABE ANY IDEA OF WHY?
Possibly in need of wheel/pickup cleaning or lubrication.
Also possible that your track need cleaning.
Oct 19, 2011 | Lionel Trains Classic Freight Train Set
My grandchildren have a Lionel Little Lines train set. The problem is that it sat for a long time unexamined. It turns out now the remote control is missing. Without that, everything else is useless. ...
First contact Lionel. If they can't help then try any local hobby store dealing in model trains. Search the Internet. There are also bidding and sales sites like eBay, Amazon, and Craigslist.
May 31, 2011 | Lionel Little Lines Train Play Set...
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
