Question about Kenmore KSM100 Stand Mixer
How much is myour Kenmore model #238.69253. In excellent condition. Only used 4 times. Bought it in 2000. It has just sat in cupboard, haven't used it.
Where can I buy a V1401ED
Call 1-800 444-4764 and ask for the parts dept.
Mar 12, 2014 | Hobart 140-quart Dough Hook, V1401ed,...
Not working at all
first and easiest to do is adjust speed control switch, video available on YouTube that will walk you through it better than written instructions
Jun 24, 2013 | KitchenAid Food Mixers
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
The turning mechanics sound clunky
HI PANNABECKERS, sorry to hear about your mixer’s malaise. It is very disconcerting to purchase an expensive brand name kitchen appliance with a solid reputation and find the reality falls far short of your expectation, but I digress on KA quality. You don’t say how old your mixer is, but I’ll assume it’s no longer under warranty (you’ve had it over a year).
By the description of your mixer’s symptoms, I concur with your assessment and say that your mixer is headed for some type of mechanical /transmission breakdown, if it hasn’t failed completely, yet. What can you do?
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers.
To disassemble your mixer you will need a regular and Phillips screwdriver, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify and replace broken/worn parts, and reassemble your mixer.
After clearing all the grease away, check to see if the gears are just loose, excessively worn or broken. If it’s worn or broken you can order replacement parts and install them yourself.
Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
If you do need repair parts, here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Finally, here are links to three excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 24, 2010 | KitchenAid K5SS Heavy Duty Commercial...
No problem just need a manual for all the parts of a K5ss mixer
Hi AUER24, you can easily download both the Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
This particular manual provides both domestic US and International Part numbers, which you will want to use, based upon your 220 volts rating that tells me you have an international model.
For future reference, here are five potential USA vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Also, here are some links to three excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 18, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
Hobart N50 stator assembly replacement
You can go to www.hobartservice.com. select parts and type the machine ML number from the data plate. here are 5 different ML options, otherwise I would have given you the part number.
It will open an exploded view of YOUR machine's build, complete with part numbers.
You can then call your nearest Hobart dealer for a cost and availability. They are still a current model, and for their size, an excellent mixer worth repairing.
Aug 18, 2009 | Hobart N50 Stand Mixer
How to buy accessories for the kenmore stand mixer model 23869253
The Kenmore 600 Watt Stand Mixer uses KitchenAid Accessories.
Dec 15, 2008 | Kenmore KSM100 Stand Mixer
Kenmore 16 speed hand mixer - KMX16E - Using speeds
I collect Kenmore products- This is random but would you be willing to sell me one of these Kenmore KMX16Es?? I don;t know how to email you on this site. If you're interested email me jasondvmgroove@gmail.com. I would also pay for shipping and pay you for the mixer and troubles.
Many Thanks,
-JASON FROM CANADA!
Jun 09, 2008 | Kenmore KMX16E Mixer
Kenmore KSM100 Stand Mixer Logo
53 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
Darial Jr Lasaria
Darial Jr Lasaria
john h
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
