Question about Epson Workforce 545 All-in-one Inkjet Printer
Epson prints on short way of paper
8x11 paper, prints on 8" up
    Master:
  • 478 Answers
Change printer settings on PC in control panel/printers/settings
Posted on Nov 12, 2014
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
Tip
Why use Epson Paper
You can try other papers with the printer. Unfortunately, when you are using non-Epson papers, it is difficult to guarantee good output. Epson papers are designed specifically for our printers, which use a unique printing technology known as Micro Piezo. The Micro Piezo printing technology, when used with our specially formulated Epson papers, produces the excellent quality output that Epson printers are known for. Unfortunately, other types of papers used in our printers often do not match the output quality of the Epson papers.
on Jun 17, 2010 | Office Equipment & Supplies
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Jan 13, 2013 | Epson Stylus 1400 InkJet Photo Printer
I have problems printing on Epson photo paper - it occasionally prints, but more often it can't pull it through. What should I do?
What type of paper are you using? The printer actually was calibrated with Epson papers, so it might not like your paper. Try using Epson papers.
Dec 09, 2010 | Epson Artisan 800 All-In-One InkJet...
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
My color photos print darker then they appear on my monitor. I use Huey pro to callibrate, I use photoshop and print to an Epson 3880, using the Epson supplied profiles. I turn off printer management and...
You need to select the correct Printer Profile for the type of paper you are using. If you are using non-Epson paper, you need to download the ICC Profile from the paper mfg. website.
You also need to check if the paper is comparable to an Epson paper that the printer supports. If the paper your using is not comparable to any Epson paper the printer supports then you might want to try using another kind of paper. Epson prefers Epson Paper. You can also try any non-Epson paper as long as it is comparable to any Epson paper the printer supports. Try to go to their website and look at the printer's specifications. It lists all type of paper the printer supports.
Jan 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Printer is not running while the power cord is ok.
Epson says....
Why is the printer beeping three times and the Paper Out light is on?
This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Q: Why is the printer beeping three times and the Paper Out light is on? A: This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Sep 30, 2009 | Epson LX-300 Matrix Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson RX595 prints "wet" on non epson paper
the reaction of the photo chemicals that are on the paper cannot be guaranteed by the printer manufacturer as they have no knowledge of its composition.
3rd party photo paper manufacturers have better compatibility results.
epson for epson, kodak for kodak, hp for hp
Apr 09, 2009 | Epson RX595 Photo All-In-One Printer
Epson Workforce 545 All-in-one Inkjet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
