Question about Sonata Housing - fuel filler door. . FUEL FILLER DOOR GAS TAN
Gas fuel filler door replacement - Sonata Housing - fuel filler door. . FUEL FILLER DOOR GAS TAN
    Master:
  • 477 Answers
FROM A BREAKERS YARD
Posted on Nov 12, 2014
Fuel filler door want open how do I get it to open?
Ford Escape Questions - Gas tank door - CarGurus
www.cargurus.com > Questions > Ford > Escape
CarGurusApr 17, 2014 - If you have to use a gas can (from running out of gas), the car will come with a ... If it's not big enough, the metal door won't release. ... ford 2009 escape cap less fuel tank I cannot get the flap door open go fill the tank 1 answer.
Opening gas tank - Ford Explorer and Ranger Forums "Serious ...
www.explorerforum.com/forums/showthread.php?t=312717
Apr 6, 2011 - 12 posts - ‎10 authors
Opening gas tank Stock 2011 - 2016 Ford Explorer Discussion. ... open the fueldoor. I am out of town so I was trying to get some feed back to let her know tonight when I talk to her. ... Push on the gas door and it will pop open for you. ... Your fuel tank is equipped with an Easy Fuel "no cap" fuel filler system.
Cap-less fuel fill stuck shut!!! - F150 Ecoboost Forum
www.f150ecoboost.net/forum/.../8119-cap-less-fuel-fill-stuck-shut.html
Oct 30, 2014 - 10 posts - ‎6 authors
So this morning I stop to fill up with fuel and I can't put the nozzle in the tank! ... station where their fuel nozzle didn't "fit" the capless thing so the door didn't open. ... You need the Ford funnel. ... Like they're saying, if the pump end isn't big enough it won't hit the latch. ... You'll get the nozzle stuck in the filler.
Jan 24, 2016 | 2013 Ford Explorer Limited
Ford fusion europe
To replace it you need to drain the fuel or drive the car until your vehicle is almost out of fuel (reserve light on )check if there is easy access to your rubber hose that goes from fuel door to your gas thank. If you can see the clamp on the hose close to the fuel thank you need to open fuel filler door, remove fuel filler cap there will be 3 or 4 screws 1/4"" size. Remove it, remove clamp from hose and air hose clamp (smaller one going to gas thank) and remove whole assembly. Installation is in reverse order of removal. Best way is to drive your car up the ramps, set the parking brake, choke the wheels and do the repair. It will probably take 1 to 2 hours of your time...
Apr 11, 2014 | 2006 Ford Fusion
I can't open the gas tank panel on a Dodge Charger
There is a fuel filler door release switch on the driver's side door in the map pocket. The fuel filler door will pop open when the switch is pressed. It is closed manually.
If this system is malfunctioning, a manual release is located in the trunk. Remove the access cover which is located on the left-side inner trim panel and pull the release cable. The fuel filler door will pop open.
Source: Owner's Manual pages 418-421
Dodge Charger Owners Manual
Jun 15, 2012 | 2011 Dodge Charger
To manuelly open 2003 Maxima gas filler door
I'm having this problem with my 2003 nissan maxima. I keep the driver side door open and keep my hand at the edge where the fuel door hinge is, and reache the button with a screwdriver or pen, and as it press the button, I push on the fuel door panel and it comes out. I'm going to replace the fuel door sooner or later. It all looks kinda dumb at the gas station.
Jan 23, 2012 | 2001 Nissan Altima
Canot turn off the gas filler door open image on my instrument cluster
open fuel filler door and see if switch isn't stuck and that the door hits the switch when closing door.
Apr 27, 2010 | 2004 Chrysler Crossfire
How do i replace the neck on my gas tank
1)Open the gas door and unbolt the gas filler neck from the body of the vehicle, using a 1/4-inch ratchet and socket.-------
2)Crawl underneath the vehicle, and use a flat-head screwdriver to disconnect the fuel filler neck from the gas tank. There is a hose clamp that secures the rubber hose to the tank, and a breather tube as well. Work the tubing off the tank using your hands.--------
3)Pull the gas filler neck out of the gas door by hand. You may need to twist it around to snake the tubing through the body of the car, but it will come out.------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | 2001 Oldsmobile Aurora
Diesal gas in the tank
You must drain all the diesel fuel out of the tank and purge the fuel lines as well or it will not start.
Apr 23, 2009 | 1998 Oldsmobile Cutlass
Cant open fuel filler door,where is the switch?
I have a 97 and there is no release for it. Just push on the right end of the gas cap door to open it. Hope that helps.
Apr 07, 2009 | 1997 Audi A4
Fuel door release location on a 2000 nissan ultima
OPENER OPERATION
The fuel-filler door release is located on the floor
to the left of the driver.s seat. To open the fuel-
filler door, pull up the release. To lock, close the
fuel-filler door securely.
Jan 16, 2009 | 2002 Nissan Altima
Sonata Housing - fuel filler door. . FUEL FILLER DOOR GAS TAN Logo
41 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
