Question about Vehicle Parts & Accessories
<!-- from fixya rte -->How do I wire led indicators to my car - Vehicle Parts & Accessories
    Habit-Forming:
  • 51 Answers
Do you have single led bulb? If so, each one needs to have a resistor diode connected to the anode
Posted on Nov 11, 2014
  • Peter Glover Nov 11, 2014
    no its a 45cm length with two wires , one black and the other is red..
What resistors do I need to fit LED tail lights to a 2012 PX Ford ranger ute
fast blinking light tells you that one of the bulbs is bad. replace the bad one and it should be fixed not need for resisters EVER
Jan 05, 2015 | Ford Cars & Trucks
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
May 25, 2014 | Ariston Technologies Dishwashers
Alarm led indicator wont stop flashing unless i unplug the 12+ wire
Most alarm indicators have an LED that flashes as a theft deterrent. It says "Hey shady guy, this car has an alarm." The 12+ wire is possibly power to the whole alarm (depends on where you're unplugging it), so unplugging it might be disabling the alarm. The light is most likely operating as intended and uses VERY little power so it won't drain your battery unless your car sits for weeks at a time.
Apr 12, 2014 | C3RS727LCD 4Channel Alarm with Remote Car...
Installed LED turn signal lights. Turn signal now blinks too fast. Solution
Hi Dennis
the indicator blinking fast because the LED use less AMP then ordinary bulb, I know an old trick to solve this problem is to connect an extra bulb to each rear indicator by running an extra wires from the light connector to an extra bulb holder.
Good Luck
Mar 02, 2014 | Cars & Trucks
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
LED does'nt work on tail light but conventional bulb is working
Your description indicates the replacement led bulb is either defective or not a direct replacement for the ordinary bulb, which I assume is a 2-filament stop/tail type because if you have a good ground and both supplies are present as indicated by the fact the ordinary bulb worked fine, the led should similarly work if it is good.
I suggest you check the supply voltages while the led is fitted. It might happen that some device in the lighting circuit is monitoring the amount of current or resistance of each bulb and will not provide a supply unless it "sees" the correct amount.
Apr 11, 2017 | 1995 Honda Civic
Replaced front signal lights with led mini marker lights
sounds like you have crossed the wiring,take apart and re try wiring 1 indicator side at a time this should clear the problem
May 19, 2009 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Jan 06, 2009 | HP Computers & Internet
LED Indicator Problems & Flasher Relay?
Modern Ducatis (and cars) don't have a conventional flasher. The blink rate is controlled by the dash cpu. The blink rate change is used to indicate that a bulb is out (by sensing low resistance). Using a resistor will fool the cpu into blinking correctly.
Nov 20, 2008 | 2008 Ducati Hypermotard
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
