Question about Dryers
My dryer only runs for 5 seconds then turns off. Any ideas on where I should start?
  • Richard Golie
    Richard Golie Nov 12, 2014
    Ok now cleaned lint out inside. It ran for one cycle then went back to the 5 second run. If I push start right away it's a little shoe
  • Richard Golie
    Shorter run then again about four times then it won't run at all unless I let it sit for ten min.. Then it starts all over again.
  • Dryers Master
  • 744 Answers
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You have asked a loaded question. If I had a model number I could better help you.
So, let me give you the probable causes:
1.) Your dryer air distribution manifold is plugged. If your sensors do not pick up air flow you unit will shut down.
2.) You could have a bad ignitor. Although, the ignitor glows red it may be worn and not have enough power to open your gas valve.
3.) The problem may be your thermal sensor. If this is bad your unit will shut down.
I can help you fix your dryer. Send me the dryer model number, which is on a label on the machine when you open the dryer door.
I will step by step walk you through the diagnostics and we will fix your dryer together
Posted on Nov 12, 2014
  • Richard Golie
    Model MDE3000AYW
  • Peter Goodwin
    Peter Goodwin Nov 12, 2014
    Ritchard; I am sorry, I am really tired tonight. I am going to have to answer you question in several comments. I suspect you have a blown thermal fuse. Yes, lets replace the thermal fuse, But what caused the thermal fuse to blow. We are going to have to remove the top cover control panel and front cover to get to it. With regret I am so tired from work. I will tell you the procedure tomorrow.
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
Maytag Gas Dryer MDG3000AWW
you check all the wirings maybe you have lost contact wirings!
Oct 09, 2007 | Dryers
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
Turns on, tumbles, ingiter glows, but no heat.
Check gas orifice for blockage. (Make sure gas is turned on obviously.)
Apr 16, 2017 | LG DLG0452W Gas Dryer
I need help with my dryer, after 5 seconds turns off and drum stops turning.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | Roper REX3614KW Electric Dryer
I have an LD LG DLG5932W gas dryer. It is not heating. I removed the front of the dryer and got it running. I can see the glow plug glow and the flame starts but only for maybe 5 seconds and then goes out....
Well for starters VERIFY tons of air flow OUTSIDE of the building. To test, pull hose from back of machine, turn on and form opinion of air volume. Then hook back up, turn on machine, go outside and see if you have similar air flow. Commonly there is a restriction. This will cause thermal limiters to stop the heating.
Jul 29, 2011 | LG DLG5932W Gas Dryer
My 5 yo whirlpool duet dryer just stopped. had run perfectly this morning. now, the power light won't come on. it is plugged in, free from lint, and tub spins freely. any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Unit begins to work correctly and after it runs a little and gets hot it cuts off. After 5 or 10 minutes it begins to run again. Does this often. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 14, 2010 | Whirlpool GEQ8811L Electric Dryer
Maytag Gas Dryer - Flame starts and then turns off 5 seconds into cycle
HI thanks for your question. the coils on the gas valve are faulty . common problem with gas dryers , replace the coils thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Maytag Dryers
Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Oct 08, 2007 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
