Question about Meiko DV 80.2 Dishwasher
My Meiko DV80.2 Final Rinse Temp reaches 180deg but my 180deg temp sensor label does not turn black showing the 180deg has been achieved
Ecolab dishwasher temperature sensor label 180deg is placed on a dish, put into the machine wash & rinse cycles ran ( wash 150deg rinse 180deg) dish removed after process and the label sensor does not trun black showing that the rinse cycle reached the required 180deg
4 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: doesn go thru cycle
This could be one of several faults- is the washpump windings overheating and cutting out the thermal overload? check for heat in pump body, is touchpad failing intermittently or is power card faulty? Try these and let me know how you get on, Colin
Posted on May 10, 2008
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
  • 86 Answers
SOURCE: Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
Posted on May 19, 2014
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
Meiko Point 2 series manual
Not heating properly. Probably a bad heater if it heats but does not reach temp in allotted time frame.
Sep 28, 2014 | Meiko Dishwashers
Rinse temp not high enough on hobart c44a dishwasher
If your water temp. gauge (on piping) is showing 180 but the digital display is only reading 125 deg. then I would remove the water temp sensor from the rinse piping on back upper part of machine (It is a small probe with wires coming out of it). Clean probe with emery cloth and put it back in to see if that changes the display. If it doesn't then you may need to replace the probe.
Aug 19, 2014 | Hobart C44a Commercial Dishwasher
Error codes 206
206 Increase in wash time Booster not ready for rinsing at right time. See error code 205.
205 Temperature increase not reached Booster heater not working, heat elements are open, defective temp sensor.
Per the service manual
Jan 06, 2014 | Meiko DV 80.2 Dishwasher
Meiko DV80.2 error 307
307 Wash tank level sensor defective (short circuit) Check connection, defective sensor, I/O board defective.
Per service manual.
Apr 03, 2013 | Meiko DV80.2 High Temp Door Type...
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Can you tell me what temperature the dishwashers reach during each part of cycle--Dishwasher model is WDF902SA Food authority have asked this of me
The wash temperature for a high temperature commercial dishwasher should be around 140F AND 160F. The final rinse temperature should be 180F to meet health code regulations. The final rinse temperature is reached during the end of the cycle for a few seconds. If the machine is a low temperature dishwasher the wash temperature and rinse temp will be around 140 F to 160 F. The sanitizing of your warewash will be done by the use of chlorine or iodine in the low temp application.
Regards
Jan 18, 2010 | Westinghouse Dishwashers
Error 211, 212!!!
Hi Antonyo,
The codes you are getting (211- 212) relate to the boiler tank behind front panel.
210 Temperature probe short circuit Check probe cable (plug contacts)
Replace probe(rinse tank)
Install probe correctly
211 Temperature sensor interruption See 210
212 Actual boiler temperature too high Contactor welded
Incorrect sensor / defective sensor
Check probe / cable (Contact plug II XA5)
Hope this helps ,regards KIT
Jun 06, 2008 | Meiko DV 80.2 Dishwasher
Dishwashers Logo
101 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
