I am unable to program rht230b thermostat - Heating & Cooling
    Master:
  • 478 Answers
Check the manufacturers website, instructions will be readily available often in pdf format for you to download immediately
Posted on Nov 11, 2014
I am unable to connect to the Internet even though the email address and password are accurate. This just happened.
Trouble Shooting - - FAQs ' FWD - Honeywell
lyric.honeywell.com/support/troubleshooting/
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
Wi-Fi 7-Day Programmable Thermostat ' Honeywell
yourhome.honeywell.com/.../thermostat/wi-fi-7-day-program...
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
FAQs - Total Connect Comfort
Dec 29, 2015 | Honeywell Programmable Thermostat Heater
Cannot program heat to come on
The flashing may indicate the need for battery replacement.
Oct 13, 2014 | Honeywell PRO 4000 Programmable 1 Heat/1...
I have a 7day furnace thermostat. I am unable to set the time, as it says it is "done". The time is NOT correct. What do I do to change it?
Most all thermostats have somewhere inside the make/model number and you can go to most manufacture web sites and put in the make/model and you can download installer/owner instructions.
Keep in mind, Most all thermostats come setup for gas, so make sure depending on the type of ac/heat you are using you program it to the type you have.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Jul 10, 2014 | Heating & Cooling
Cant program remote
I'm going to assume you are meaning that you are unable to set the "target temperature" for the thermostat?
This remote control system can be thermostatically controlled when the transmitter is in the THERMO mode (THERMO must be displayed on the screen). To set the DESIRED room temperature, press the MODE button to place the transmitter into THERMO mode, then press the UP or DOWN button to select the desired
room temperature. The highest SET temperature is 99 degrees Fahrenheit (32 degrees Celsius).
The complete owner's manual can be downloaded from the product page below, just scroll down to the bottom and click the link.
Skytech 3002 Thermostat Fireplace Remote
Sep 23, 2012 | Skytech 3002 Fireplace Remote Control with...
Unable to get the auto feature to work
THIS CUOLD BE A BAD THERMOSTAT. IF THE FURNACE OR A/C COMES ON WHEN IT IS IN FAN ONLY MODE THEN YOUR THERMOSTAT IS BAD. IF THE T-STAT IS PROGRAMABLE LOOK AT YOUR SET UP MANUAL AND MAKE SURE IT IS PROGRAMED CORRECTLY!!! GOOD LUCK
Oct 17, 2010 | Heating & Cooling
I have installed my Honeywell RTH2310 thermostat from an older mercury one properly and it seems to work fine. However, I am unable to get it to operate at the set temperatures. I set the programming to...
Hello Vinny Fear not the thermostat has a built in (factory) deadband of 1 or 2 degrees on purpose to keep the unit from shortcycling.It needs to maintain a minimun run time for the equipment's sake.This is normal and can't be adjusted.
Sep 17, 2010 | Heating & Cooling
I am unable to set the wake and sleep setting and have to use the hold mode to control heat.
Go in to the cooling/mode program check the temp/time setting must not conflict with the desired heat setting.
Mar 21, 2010 | Honeywell Electronic Programmable...
I am clueless how to set programs on our Honeywell thermostat. I am unable to find a part number or something that distinguishes the type so I may get a manual of operation. Is there a general...
Start at the 'menu' button. Push button and scroll through to 'program' section. You will need to set the date and time and all that stuff. Then just keep going through the menu until yo find the program function that you want. Set the days and times yo like. You won't hurt anything so be bold and just keep at it, you will get it!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 | Honeywell Programmable Thermostat Heater
I want to install a new thermostat on my furnace, but the wire connections on the old thermostat are not marked. I have been unable to locate a diagram with wire labeling. Can you help?
Your t-stat has a override program on it look for the hold button and cancel the function. Should be able to just press the hold temp button and it will resume the normal program.
Jan 01, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
