Question about Pool & Spa
Please help I have a intex pure spa and it has been working fine but now it is reading E96. I unplugged it and plugged it back in but it just beeps and shows E96. Please help
  • Tisha Lloyd
    Tisha Lloyd Oct 21, 2016
    Where's the fuse
  • 1,631 Answers
According to Intex - E96 is a "System Error", and the most common problem associated with that fault code is a failed GFCI Cord End.
Look here for replacement;
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
Posted on Apr 11, 2015
    Master:
  • 477 Answers
Intex E96 code means there is a heater fuse error , replace the fuse & your problems should be fixed
Posted on Nov 11, 2014
  • dave
    dave Feb 12, 2015
    Any idea how to replace this? Also I thought that it was the E97 code that was the heater fuse? I need to replace mine and hopefully it will be up and working agian!
  • Tisha Lloyd
    Where's the fuse
Sorry what dose e96 code mean
It is helpful to post device (or vehicle), brand, model, and sometimes year when posting a question. For instance, this question was posted in cars and trucks. But as code numbers are sometimes by sheer coincidence shared with other devices, this number is the code for an error related to a spa:
Intex Pure Spa E96 slow reset solution
Aug 08, 2017 | Cars & Trucks
My Intex spa turns on heat light comes on ,only for about 2 minutes and then goes out then flashes e96 and is beeping, How do I fix ?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Mar 14, 2016 | Intex Pool & Spa
How can I fix code E96 ?
The E96 error code t - the control console (the bottom part with the pump. call intex customer service and order a new one, you need your receipt.
Jan 17, 2016 | Intex Pool & Spa
I keep getting a E96 code on my intex pure spa and I seen when other people have asked and we're told it was the Gfi well my husband just eliminated the Gfi and no it still shows code E96 what else could...
RE: INTEX PureSpa - E96 error code.
This also happened to me, just after having it for 1 year. I followed the scanty instructions in the troubleshooting section to no avail. I called for "technical assistance" twice and got random females with heavy Asian accents and absolutely NO technical know-how.
ME: "I got a E96 error code."
AL (Asian Lady): "When you buy it? If less than year, we send new base."
ME: "It's been longer than that, can I just buy the base then?"
AL: "Yes, $380 and we send it you."
ME: "But I paid $350 for the whole thing new!"
AL: "It's cheaper just buy new one."
ME: "Sure, but can't we troubleshoot this one?"
AL: "We can no more troubleshooting."
No supervisor was available, I was told to hang up and try again for someone else. Persisting, I pried info from one that it was "pump bloken," from the other "bad consore." I believed both were full of it and had no idea what they were talking about.
MY FIX: I disconnected unit from spa. Removed console from base. Turned base upside down to inspect pump and find any ID markings. Found no obvious problem with pump or heating mechanism. Spend few hours time researching cost to buy identical pump. Gave up. Returned to unit, reassembled it, and it worked perfectly!
MORAL TO THE STORY: Intex products are fine, their Tech Support is a joke. I suspect the console had detected air in the pump and that it was stuck in a system error cycle which required a prolonged rest from any power input to refresh. Also, turning the unit over (while inspecting it) may have flushed any remaining water around the onboard pump sensor.
Don't listen to their know-nothing "tech support" when they suggest it is a GFCI problem, (or some of the others here who give this advice without really knowing).
Just keep it fully unplugged for at least a few hours to wipe the system memory!
Since it's a circuit board, it's like a mini-computer. Actually, it's just like a modem that requires resetting. If you unplug it and then replug it too soon, you've solved nothing, the on-board circuitry retains enough voltage to prevent it from resetting. You need to keep it unplugged for an extended period of time.
Hope this helps. Best of luck!
-Matt
Nov 12, 2014 | Pool & Spa
What errors does Intex E96 code cover
make sure pump is primed
Sep 14, 2014 | Pool & Spa
Intex spa
You have a bad GFI plug. Replace it and you should be fine.
Apr 13, 2014 | Intex Pool & Spa
E96 error code
E96 - On what?
Need more info.
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
Pool & Spa Logo
1,884 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
