Question about Saws
How do I lubricate my 6507 sawzall. I have the recommended grease, but don't know how to pack each in the correct spot.
4 Suggested Answers
  • 384 Answers
SOURCE: Sawzall model 6507 goes dead when horizontal.
Loose wire connection in electrical cable.
Posted on Sep 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: My dog chewed up cord. How do I repalce Milwaukee
this should be a twist lock cord and all you need to do it twist the connector at the handle area and pull the cord off and buy a replacement, make sure whether it it grounded (3 wire) or double insulated (2 wire), you can go to Milwaukeetools.com and with your serial number look at a schematic for this tool and they also have a dealer locator to ensure that you get the proper one. Let me know if you need more assistance.
Posted on Sep 26, 2011
SOURCE: sawzall runs but wont reciprocate
Seems like the wheel and gear are not hooked up, reopen it and check the reciprocating arm connection is where i would start
Posted on Apr 05, 2012
Why is my reciprocating carver leaking black goo?
Terri, this is grease leaking from seal on col-let shaft, or loose bolts/cracked casing. Take apart and repack gears and housing with lithium grease ( do not over pack) and change seal if possible.
My old sawzall from the 1980 has started to leak
sawsall leaking grease
http://www.shopfloortalk.com/forums/showthread.php?t=24494
Feb 24, 2016 | Saws
Greese spots on laundry from my G.E. washer
need these questions answered 1st in order to address your issue. are the spots black grease as in the type of grease used to lubricate the drum mechanism? also, did you purchase the washer new or used and have you ever had it serviced?
Aug 24, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Iv'e just stripped down and repaired my gearbox on my scooter. however i don't know what oil, grease is required could you help.
hji, on most scooters it recommended you use a semi fluid grease, recommend by shoprider on their scooters... plain grease is not ideal as it sticks to the sides of the casing , not lubricating anything ...
a thickest oil would also be ideal, however remember if no gasket is fitted it may leak...hence the semi fluid route..
http://www.castrol.com/en_us/united-states/products/truck-and-bus/greases.html
Regards
Rob
www.gewizrepairs.co.uk
Aug 05, 2014 | Shoprider Health & Beauty
Sawzall runs but wont reciprocate
Apr 05, 2012 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
How to dissasemble sawzall for cleanning
first unplug the tool and remove the handle half, using compressed air blow all the debris out of the brush area and in the front where the gearcase meets the motor housing, blow thru there also. I don't think I would recommend taking the gearcase off but if you are mechanically inclined you can go to milwaukeetools.com and with your model and serial number download a schematic for this tool. The gearcase insulator boot is usually difficult to remove. Let me know if you need more assistance.
Dec 05, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
My dog chewed up cord. How do I repalce Milwaukee Model 6507 Sawzall
Sep 19, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
I'm changing the cutterhead bearings in a Mclane Lawn edger. Do I need to pack the housing with grease?
Was it packed with grease when you took it apart??? If there are gears there lubricate yes! Good Luck..
Mar 12, 2011 | Garden
50,000 mile service
48,000 miles or 48 months
Maintenance Service Schedule 2007 dodge
Change engine oil and engine oil filter
Rotate tires
Lubricate drivetrain / steering / suspension
grease fittings (if equipped)-except Powerwagon
Lubricate front drive shaft fitting
(2500 / 3500, 4X4 & Powewagon)
Lubricate tie rod end links - Powerwagon
Check automatic transmission fluid level
Check manual transmission fluid level
Check the coolant level, hoses and clamps
Inspect exhaust system
Inspect brake hoses and brake linings
Inspect the CV joints/U-joints (if equipped) and
front suspension components
Check spare tire for proper pressure & correct
stowage
Lubricate outer tie rod ends 2500/3500 4X4
51,000 miles or 51 months
(2500/3500, 4X4 & Powerwagon)
Inspect brake hoses
Jan 04, 2009 | 2007 Dodge Ram Truck
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Saws Logo
135 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
