Question about Cell Phones
My fan is not working on my defy731
The thereof an has stopped working all positions
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Mistype?
Posted on Nov 11, 2014
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
How do i stop the supply fan
Check fan switch, if in On position fan runs continous Auto position, fan cycles with heat /cool. If in Auto than fan relay,logic board failure or short in wiring.
Oct 16, 2014 | Heating & Cooling
Fan just stopped working
Check your reverse button & make sure it's in the right position & not in the middle. Also, check your capacitor. If the fan has a remote, you probably need a new receiver.
Jan 16, 2014 | Dryers
A/c stopped cooling a couple of weeks ago and now the blowers have stopped working too What could be the problem,all fuses are ok.
For the ac to stop working either the compressor clutch is not getting power or the gas is too low so the low pressure switch has switched the compressor off to stop sucking in air through the leak. The blower is controlled by the fan switch which is a 3 positional switch that has a resistor for each position. These resistors have a habit of burning out so the fan will not work. The resistors are in a block located in the blower housing. So you have two faults to fix.
Aug 31, 2013 | Mitsubishi Colt Cars & Trucks
My HP Pavillion Entertainment laptop's screen is black. Power works, battery is fine...what can I do?
if you are in Toronto-Canada -- will perform this procedure for you , minimal cost
or let someone do this for you, who is familiar
its a heat sink (or lack thereof) issue with the CPU and video chip on board -- there is too much heat disspiated and not enough copper exposure to the video chip to absorb that amount of heat generated
before you do this let the computer cool down first for 30-60 minutes
one good thing to do , easy .. remove the screws from the plastic back cover, and remove the heatsink fan .. apply thermal compound grease to the heatsink (that sits on the CPU) and gently place it back -- do not put too much thermal compound, just a circular amount around the heat sink ..place it back, put all screws back
let me know how you make out
please send me positive response
Oct 19, 2010 | HP Pavilion dv9000z Notebook
How can I repair the radiator fan that has stopped working?
it could be a fuse, relay, or the tempurature sensor. run a wire from positive on battery to positive on fan and ground other wire if needed. to see if fans are ok, if the fan run this way, check the above .
Jul 18, 2010 | 1990 Dodge Spirit
1996 honda passport defrost has stopped working
The directional door or actuator thereof is inoperative. This door moves when you choose a vent at the selector, and directs the air to the desired vent(s.) When the actuator goes bad, loses vaccuum, or an electric door motor fails, the air will go to a default position that is usually the defrost. Since you are stuck at the dash vent position, closer inspection at the door itself is required. Could be a stuck door or actuator; or less likely, a faulty controller. Good luck, let me know if you need more info. THanks, TT
Dec 14, 2008 | 1995 Honda Passport
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
