Question about Refrigerators
LG LRTBC1825T refrigerator Water pooling under veg bins. How do I remove inside back panel in freezer in order to put tiny bit if clorox down drain to clean it out. Don't see any screws at all. What is best, easiest way to clear rhe drain line? Any ither ideas of what is causing about 1/2 cup water a day to drain to bottom of inside refrigerator. I see
    Habit-Forming:
  • 51 Answers
Switch off refrigerator, use a small syringe filled with hot water, shoot through drains line
Posted on Nov 11, 2014
  • Faye Petrus Nov 11, 2014
    Thanks. I can't figure out how to get to the drain line in order to syringe some warm water through it. Is the drain line inside or on the outside. I looked for it in the freezer but couldn't pull the back inside the freezer panel off.
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Apr 27, 2009
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
My refrigerator is leaking water into the freezer compartment, refrigerator compartment and the outside bottom of the unit. what might be wrong? Is it something I can fix or do I need to call a repairman?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW VEG. BINS, HEAVY CONDENSATION ON WALLS OF REFRIG. CANT FIND A DRAIN HOLE AT BASE OF FREEZER OR FRIG.
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Aug 02, 2009 | GE Refrigerators
Magic Chef CTB1722 refrigerator leaking water from inside fridge. The water pools under the fruit and veggie bins and leaks onto the floor.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 12, 2009 | Refrigerators
Water-on-bottom-of-veg-bens -cleaned-tube-drain-but=still-same-water-still-goes--to-bottom-of-veg-bens. donald-clemente.
Jul 02, 2009 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
