How do I turn off the internal speakers, when connecting to home theatre stereo or head phone
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Mute button on connected device
Posted on Nov 11, 2014
5 Suggested Answers
CLUEPATEL
  • 138 Answers
SOURCE: 5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Posted on Dec 08, 2007
CLUEPATEL
  • 138 Answers
SOURCE: HOME THEATRE SYSTEM
I think you must change the settings and try it out! it will make a great change.
tech240
  • 169 Answers
SOURCE: probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Posted on Apr 25, 2008
SOURCE: HOmetech HT503 8 ohm speakers
WITHOUT ANY PROBLEM. THE SOUND WILL BE LITTLE SOFT BUT YOU CANNOT MAKE ANY PROBLE USING 8 OHM ON 3 OHMS AMPLIFIER
Posted on Aug 07, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
I am having 21 inch onida black 200 tv .I have recently bought philips home theatre. please let me know how to turn off internal speakers of onida tv and how to turn on external speakers to send audio...
By the looks of it, the only output you can use from the tv will be using the 2.5mm jack plug headphone socket, get a cable to convert this into twin phone (red/white) for stereo sound to your amplifier. (they are very cheap £2 or so) The Home theatre system should be able to give you a psuedo surround but you wont get full surround.
May 02, 2011 | Audio Players & Recorders
I have a Dynex Flat Pannel TV with a DVD player in the TV. I have it hooked up to my HD line coming into the house. My question is: Is there a way to hook speparate speakers from the TV and by-pas the...
Yes you can provided your tv-has a headphone jack. Just plug in any regular computer speakers or the like into the headphones jack and the audio output would be switched to external speakers automatically. On the contrary if your tv does not have a headphone jack then you will need to obtain a home-theatre system and connect the stereo audio out ports to the audio in of the home theatre system. They have become very affordable these days and I have seen a Philips home theatre system(2.1) starting at around 120$.
Apr 04, 2011 | Dynex Televison & Video
When i turn on my stereo system it shows "protect"
Protect mode is an error code detected by the processor. A lot of possible fault is caused by this error code. This maybe external connection or internal problem. First dis-connect all the input/speaker/antenna connected in the unit. While it is unplug on the wall power it on for a min to drain all the stored electricity on the cap. After this you can try to plug it and power it on. If the symptom is still there this is an indication that you have an internal problem. If the unit works normally then the problem is between what you have been disconnected. The high chance of fault is the speaker wire or the speaker itself.
I've advice you to send it to repair shop to isolate the problem because the caused might coming from the bad power supply, fault in pre-amplifier stage, fault in output IC. This is quite technical.
Also check if the unit is under warranty before taking any action which will void the warranty.
Hope it may help you.
Have a nice day!
JDVillanueva
Feb 04, 2011 | Audio Players & Recorders
Hi,i'm stuck on connecting speakers into motherboard ref number MS6787 ver:2 any help please regards richard
I assume you are referring to powered external speakers (not an internal PC speaker) in which case you need to plug in to the green headphone output.
Sep 09, 2009 | Intel Motherboard
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Ipod sound through home entertainment
get a stereo to phono cord.
connect the stereo pin to the ipod (ear pin) and connect the phono cord the the input section of the home theatre.
after all this just put on everything and start the music on the ipod.
if it does not come just increase the volume of your home theatre.
hope to hear favourably from u.
thank u and good luck.
have a nice day.
Jul 05, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
 Grubhead
Grubhead
