Question about Sewing Machines
Singer 9116 needle hitting shuttle ****.
Outside of slot in shuttle hits needle.
    Master:
  • Sewing Machines Master
  • 661 Answers
Is needle bent? Are the feed dogs aligned? Shuttle clicked in? Is the needle set for zig zag? Could be one of those things.
Best wishes
Posted on Nov 26, 2014
My shuttle on my singer prelude gets some small scratches and I have to remove them and my sewing machine will see great until it happens again
Those scratches usually occur because the needle has deflected and hit it. This happens sometimes, however, sewing slower when going through heavy fabrics, across seams, never pulling on fabric, etc. will help prevent it from occurring. Also, NEVER sew across pins (have you ever had the needle break and the tip fly up into your face? Not a good idea if you value your eyesight!).
If the scratches are minor, they can sometimes be smoothed with very fine sandpaper or emery board. When it gets larger nicks and gouges, it may need to be replaced.
Oct 14, 2016 | Singer Sewing Machines
How do i put the shuttle back correctly to stop needle hitting shuttle
If you are inserting the shuttle and locking it in place but the needle continues to hit, the needle may be bent. If a new needle is installed and it continues to hit, most likely the needle/hook timing is off. Take it for service.
Feb 23, 2016 | Sewing Machines
Why is the needle tip hitting the shuttle?
First make certain that the needle is the correct length and it is up into the needle clamp as far as it can go. if that doesn't work, the needle bar may have come loose and is too far down. Another possibility is that the timing has slipped. Your authorized Singer repair center should be able fixit easily.
Sep 01, 2014 | Singer Sewing Machines
Needle hitting the shuttle
since you were sewing harder material it's possible that the
machine jumped time & needs to be checked at a sewing machine
shop
but try putting in a new needle first
if it still is hitting the shuttle then it needs to be checked.
Oct 16, 2012 | Singer Sewing Machines
5417 Mechanical Sewing Machine: ok when my needle goes down it seems to hit someth...
If the needle is not in all the way it will bottom out in the shuttle, or if you bought new needles and accedently got the wrong ones. If the needle does not enter the needle plate far enough to be bottoming out then the machine is out of time. You know i was about to hit post it and I realized I didn't think about, if the needle is bent it will hit the hook. so check those things hope it works out.
May 18, 2010 | Singer 5417 Mechanical Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
My singer 7470 is skipping stitches on the left hand side ie. if im doing letters it misses the bottom 1/3rd. and other wider patterns misses about 1 in 12 ? i have cleaned bobbin case and it has obviously...
Take the machine in for service by an authorized Singer tech.
Hitting the bobbin case may have knocked the timing off and the shuttle may have to be replaced.
Trying to fix this yourself may lead to more problems and additional expense.
Mar 27, 2010 | SINGER 7470 Sewing Machine
Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
May 12, 2009 | Singer 3116 Simple
Singer sewing machine Merrit. Needle is hitting something and not going into hole
turn the machine slowly by hand as the needle goes down check it does not hit the foot ,then the hole of the plate.
If it enters the hole and then stops aganst something it is possible the shuttle or bobbin is not in right take them out and replace them again.if the problem prisists take the needle plate off and warch as the needle goes down what it is hitting.
if the hook or shuttle is in the way the timming could be out.
Aug 01, 2008 | Singer 3116 Simple
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
