Question about Kitchen Ranges
I have a tiger 944 gas stove and have recently had the pilot assembly replaced. Since then the stove has been giving off much smaller flames than it used to do.
    Master:
  • 477 Answers
Was there a question in there? as that is just a statement!!
Posted on Nov 11, 2014
  • Mohammed Umar Nov 11, 2014
    A statement indeed but also my problem too, you see the flames were much larger prior to the pilot assembly being replaced and now they are alot lot smaller, and i was looking for possible answers as to why this maybe because the gas engineer was baffled to.
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
joboo1
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
landsend
  • 1066 Answers
SOURCE: Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Posted on Mar 26, 2009
SOURCE: GE range stove #317B6641P001
have a ge 317b6641p001...the oven is 50 degrees hotter...
Posted on Apr 06, 2011
Why won't the broiler flame on my kenmore gas stove adjust?
you may have to replace the orifice with a smaller one. Follow the gas tube from the broiler to see if it runs thru the same regulator. Some units use a pressure regulated gas valve.
Aug 22, 2014 | Kitchen Ranges
I have a new (less than a year) Brown gas stove that has been installed and running reasonably well until recently: the problem is that the oven pilot always goes out once the oven is turned off. In the...
It may be the thermocouple assembly...this is a device that senses that the pilot is in fact lit...it looks like a copper tube with a smaller tube coming off of it and the smaller tube goes to the gas valve and the larger part of it sits just above where the pilot flame is..this allows it to get hot telling the valve that there is a pilot and that it is ok that the valve turn on providing the gas to start oven..if this part goes bad then the pilot will not stay lit..themocouples are available from most hardware stores and are usually universal
Jan 22, 2011 | Ovens
Have a comfort glow heater ventless natural gas. need to know where to get the little part that the pilot light flame comes out of. need a new one. cleaned the stove last night. after, the pilot light...
Look for a small hole or two in the part the pilot flame comes out of. These may be partly blocked. They allow air to mix with the gas for the pilot.
Mar 31, 2010 | Heating & Cooling
Charm glow gas heater won't stay lit changed thermocouple and it worked for 2 days
Dust build up inside the pilot light burner assembly. A clean pilot makes noise and has a blue flame when it is burning. A dirty pilot has a quiet and smaller flame with an orange tip.
Oct 15, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
I have an older model brown stove and cannot light the oven pilot
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
Apr 08, 2009 | Tappan TGF657 Gas Kitchen Range
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
My propane heater not working right
This could be due to insufficient gas pressure. When you turn the knob to get the flames going, observe the pilot light. If it gets smaller, or burns with less intensity, it means you have insufficient gas pressure. If the pilot light gets smaller, the temperature of the thermocouple drops, so the electrical current produced by the thermocouple also drops. The stove interprets this drop in voltage to mean that the oxygen level in the room has dropped (because a drop in oxygen content likewise would cause the pilot light to get smaller).
Dec 22, 2008 | Procom QL300TYLA Heater
Viking 4 burner gas stove spark will not stop after flame starts
make sure that the electronic pilot gets hot by the flame of the burners, some times the gas air adjustmet is open to much and the flame will not get to the starter or electronic pilot, the electrode has a sensor that knows when the flame is on, if you see that the tip of the electrode is not been touch by the flame it will not stop, tiking. if that is not the problem replace the electrodes, or electronic pilot the same thing.
Dec 06, 2008 | Viking VGIC305-4B Gas Kitchen Range
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
