Question about Velbon DF-60 Tripod
How can I dissasemble the head of the tripod to clean it and lubricate it and what lubricant should I use for a smooth panning?
The tripod is new. I used WD-40 to lubricate it but the head still doesn't move nice and smooth. Sometimes gets a little bit stuck creating a jump on the video when panning.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
I think these where made by rocket scientists!!!
twist the panning handle counter clockwise till it comes out...on the side should be 2 small covers for the screws remove cover and screws BE CAREFUL of the tension tab (holds camera on) lube with silicone or any automotive grease.... reverse instructions!
Posted on Nov 11, 2014
Central shaft is stuck on my dolica tripod proline
Try completely removing the thumbscrew that retains its position, then spray a very little penetrating lubricant inside and see if that will loosen it.
Aug 04, 2016 | Dolica CX730B105 73-Inch Proline...
How can I fix the jerky motion of the 804RC2? What kind of lubricant can I use on the head?
Parts and a diagram can be found here: http://www.manfrottotripodparts.com/head804rc2-3.html
Silicon grease in very small quantities is the best lube to use. DO NOT use oil or liquid lubes like WD-40. These will flow and make the head messy and may "wash" the other lubes away.
Jun 09, 2011 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
Giotto Aluminum Tripod # 9160 - legs sticking - took legs apart, cleaned but did not lubricate - still sticking.
Call us at 800 735-4373 regarding serving Giottos tripods and for our address to get this properly repaired. It does not need lubrication.
Apr 27, 2011 | Giottos Photography
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
Head does tilt smoothly on 516. How do I get it smooth? Eric
Not fully understanding your question. You stated that the "head does tilt smoothly on 516. How do I get it smooth". What are you asking exactly? How to smooth out the pan as well, or how to make it tilt even smoother?
Sep 03, 2010 | Bogen Communication Bogen / Manfrotto 516...
My tripod legs froze up. I got sand on them and tried to lubricate with WD40. How can I free them up?
first of all be carefull with you tripod but you could take it in to a shop a see if you could get it fxed or it might come apart and you could clean the insides out or you could get a new or used one on ebay for under $20 have fun!! :)
Apr 01, 2010 | Photography
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Hitachi HB C103 bread machine pan seal
The problem isn't the seal, it is the bearing. You need to disassemble it, clean it, and lubricate it. Turn the pan upside down, and there's a C-ring that you need to pry off. Then you can tap the shaft through the bearing, and it will fall out. Clean the shaft and inside of the bearing, lubricate it, and reassemble.
I usually lubricate with vegetable oil, to avoid any chance of noxious contamination getting into the bread, but I've read a recommendation to use liquid graphite lock lubricant, available from NAPA Auto Parts, to prevent the bearing from sticking again as soon:
http://reviews.ebay.com/How-to-lubricate-your-bread-machine-pan-shaft-bearing_W0QQugidZ10000000016577277
BTW, be careful of that rubber seal -- they are apparently irreplaceable! (I need one, if you find a source.)
-Dave
http://www.burtonsys.com/email/
Oct 28, 2009 | Kitchen Appliances - Others
With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
Mar 14, 2008 | Photography
Velbon DF-60 Tripod Logo
349 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
