Question about Frigidaire Washing Machines
My affinity front load washer drum will not move after the water goes in nothing else happens.
    Master:
  • 477 Answers
The belt needs tightening, remove the back, you will see a belt which goes around the drum & back to the motor, the motor has an adjustment feature that by moving it away from the drum tightens the belt, there should be no more than 8mm deflection either side of the belt when it is adjusted correctly, when this is done replace the back & your machine should spin & wash, If it does not after this simple fix then you either need a replacement panel (Electronics) or a replacement motor
Posted on Nov 11, 2014
ngfam1
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
onthejob5130
  • 640 Answers
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Posted on Jun 18, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Scraping sound when you spin the drum by hand. The washer is two years old. front loader affinity model.
does the drum move as you spin it (if so poss stuts) makes a scrapping sound
Just check to see if the drum moves more than it should
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washer was moved from one location to another; when turned on at new location it makes a noise and code of DR
Many washers have a sipping rod or bar that needs to be inserted into the unit from the rear or the bottom; this keeps the drum and balance mechanism stable while being moved. Either, the bar/rod is still in the unit and causing the noise, or it was never inserted for the move and the drum balance is off kilter and need to be physically repositioned so the drum sits well centered. Most likely, nothing is broken; just a nuisance. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front loading washer
Pull the top off by removing the screws on the back of the top of the washer then the top will push back and left off. From the front reach down on the left side , there is a hose that gos from the bottom of the soap dispenser the gos into the front of the drum, you should be able to pull it out of where it gos into the drum chances are there issomthing stuck in it or there in the drum where the hose gos in. Note you may have to take the screws out of the soap dispenser and push it back a little to get your arm down in there to get ahold of the hose.
Hope this helps....
Brian's Appliance Repair
Sep 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
