Question about Kitchen Appliances - Others
I have a CME 256 as 1d machne and the fan will not run. replaced the fan and thats not the issue. do I need a new control board?
Everything else seems to be working and I have no error lights on the control board
    Novelist:
    Champion:
  • 373 Answers
Check the fan control switch. The switch closes at 240 PSIG. Then fan comes on. The switch opens at 190 PSIG. Then the fan will cycle off until presser rises. Check to make sure you have power to the switch while in freeze cycle if you do then check the other side ow switch to make sure you have power going through switch if not then either switch is bad or you are low on refrigerant. The switch part number is 11-0479-21. either way if switch is bad or low on refrigerant the refrigerant will need to be recovered and switch will need to be removed and sweated back in and a vacuum pulled and charge weighed back in. Do not replace the control board.
Posted on Nov 11, 2014
  • howard thompson Nov 11, 2014
Hosizaki ice machne 3 beeps then after i reset it it runs for 7 seconds and shuts off?
the 3 beeps means that the freeze cycle is longer than 60 minutes. This could be because: float switch stuck, water valve leaking water into the sump, low on freon. If not one of those, it is a more technical issue that would require a service tech. Reset button is a small white button on the control board. Press it while the power is on to reset it.
May 21, 2014 | Hoshizaki Freezer Commercial Ice Machines...
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Hitachi CME LCD 201 Flat screen TV and
Just the exact model and serial numbers. Or you could search for a "universal" remote that supports it.
Jul 10, 2010 | Hitachi Televison & Video
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor, Condensor Fan and freezer fan not running
have u checked the timer must components are powered by this timer
Jul 24, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Outdoor fan is running continuously without using Wireless Remote Controller
Bad control board on the condensing unit up top. The board needs to be replaced as it is sending the message that the system is calling for cooling/heating all the time and doesnt know what to do. If you continue to let it run this way you will ed up having more major issues
Jun 01, 2009 | Fujitsu Heating & Cooling
Infocus screenplay 7200 fan failure with new lamp After powering on, red LED blinks 4 times which means fan failure of the fan that is part of the lamp module. Already returned initial new lamp and got...
Not sure if this helps with the 7200 bu had a 4805 with a failed fan issue. There are two fans inthe unit, one smaller one that cools the color (colour) wheel and the larger one that cools the lamp. This unit had a problem with the larger lamp fan not turning. Unplugged and disassembled the unit to get the fan out and tested the fan using a 9v battery and a couple of wires (best to uplug the fan from the controller board so you are not forcing voltage into the unpowered controller board... that said, I did it hooked up just peeling back the label in the centre of the fan and touching the wires to the solder contacts) The fan worked fine so figured the controller board was the issue, so this wasn't going to be a simple "buy a new fan" issue.
Here is where your mileage may vary...
I decided that it would be OK to just run the fan. Unplugged the fan and powered it from the 9V battery and assembled the unit and powered it up. Found that there was 7v available on the power board at the second pin that was alwasy on when the power switch was on (thats the positive 7 V pin, but measure it with a meter since we are talking about a different projector) and just wired the fan direct to pin 1 and 2 (1 is ground on the 4805, 2 is +7V) and so now whenever the main power is on the fan runs, so after ti cools down I just power off the main power when not in use... or let the fan run if the noise isn't an issue. Crude but effective fix.
Mar 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
GE Fridge intermittent
I had the exact problem with my GSL25JFRFBS. It turned out to be a bad control board. The service technician that replaced the board said that the lights dimming on the on the ice/water dispenser is a direct indication of the control board being bad. This cost me $303.53 and my refridgerator is only a little over 2 years old. You can buy a new control board - WR55X10656 from GE online for a little over $157.00. From what I've found, this is an inherit issue with this model.
Oct 30, 2008 | Sub-Zero 650 / O Bottom Freezer...
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
