Question about Dishwashers
How do I fix an error code --
After wiping the top panel clean with a damp rag this is all that shows on the front panel. no other button works.
    Master:
  • 477 Answers
We need the make and model?
Posted on Nov 11, 2014
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
Ink system failure error code: 0xc18a0306 what is the problem and the cure
Ink system failures can be caused by a number of things. It could be a temporary error, a bad or dirty print head, or a system failure.
For pictures see: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=1156652#N998 . Expand the section "any other error code" if you need to.
First try resetting the printer. With the printer on, unplug the power cord from the printer then remove the other plug from the wall outlet. Wait at least 15 seconds. (I also pull the data cable from both the printer and the computer when using a USB cable - some power is provided through this cable.) Then plug the power cord into the wall outlet and then back into the computer. Turn the printer back on if needed. Check if the code is still present.
Next try cleaning the print head. With the power on, open the cartridge access door. Wait until the cartridge carrier stops moving. Remove all of the ink cartridges by pressing on the front tab and lifting them up. Then lift the grey handle and pull the print head straight up.
With bottled or distilled water and lint free clothes (coffee filters will work). Dampen a cloth and wipe the electrical contacts working form bottom to top. Do not touch the ink nozzles. Continue until there is no ink left on the contacts. With another damp cloth, wipe the edge between the nozzles and the electrical contacts working form left to right. (Keep your fingers away from the contacts.) With another damp cloth, wipe the ramps working away from the nozzles. Again continue wiping each area (using extra damp cloths until there is no ink left). Then dry each of these areas with a dry cloth. Take another damp cloth, and wipe the contacts inside the printer. Work from top to bottom on these contacts. Dry the area. Replace the print head, lower the gray lever, and reinstall the ink cartridges. Close the cartridge access door.
If the error persists, try resetting the printer by unplugging it while turned on again.
If the error still persists, either you need a new print head or the unit needs service. If you get a new print head, you will not be able to return it if that doesn't solve the problem.
I hope this helps.
Mar 22, 2011 | HP Photosmart D7160 InkJet Printer
My Whirlpool Duet dryer has a strong. "Burnt"
Hi
The burnt smell usually comes when the motor is going bad, as the unit works I won't recommend you to use it for a long time and get the motor checked-replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The printer is 2-3 toner cartridges old and has developed a paper jam where the second sheet through stops almost immediately upon being lifted from the drawer. Is this a drum replacement?
Not a drum replacement, use a damp rag and wipe the rubber roller above where the paper is lifted, and also gently hold that damp rag on each of the exit rollers on top where the paper comes out as you open and close the front door to make the printer run for a few seconds. should help those paper jams.
Dec 28, 2009 | Brother HL-2040 Laser Printer
What do you use to clean the screen on the plasma 42" Samsung screen?
Plasma's have a glass front so you can use windex, LCD's you should use warm water on a damp rag, not soaked and wipe gently do not push on the face. do these when the set has been off and the front is cool.
May 09, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Error code f11
F-11 is communication error between the Motor control unit and the Main CCU. Either of these or both could be bad. Sometimes unplugging all the connections from the CCU (under top panel) and plugging them back in will fix the problem. If fixed, there's a bad connection at the CCU.
Feb 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Horizontal line print errors
  1. Hold the cartridge upside down, with the bar-code label facing you.
  2. Take a damp paper towel and use it to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
  3. Continue doing this until the printhead looks clean.
  4. Then dab the cartridge on the towel to make sure the ink is flowing.
  5. Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    3. And then perform This
  6. Press the Mode button on the operator panel until the Copy light comes on.
  7. Press the Menu button once to enter the menus.
  8. Press the down arrow button until you see Clean Cartridges.
  9. Press Select. The 'Clean nozzles' page will now print.
Oct 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
The low button light is going out.
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
