Question about Retail Supplies
<!-- from fixya rte -->How do i load a price tag labler - Retail Supplies
Tip
How to remove price tags on the packages of your toys for MOC collectors
These are some ways : you can do an old school way of removing it by slowly/gently removing the tag / use a hair dryer and set it on medium heat and directing it to the tag, then after awhile, remove the tag / use another tape to remove the tag and also on the sticky residue after removing the tag / apply small amounts of acetone or wipe out on the tag and gently remove it. Hope this helps out.
on Sep 16, 2010 | Toys
How much do pet ID tags cost?
Pricesfor pet ID tags really vary, depending on whether you want to personalize it ornot, or if you go for laser engraved or just regular engraving. Check out thisGoogle link to compare prices
Jul 25, 2012 | Pets - Others
Usualy i have problems with this printer because the price tag stick to the film and destroy it, and the price tags to. camn you present me a solution. Many thanks
Either you are heating too much so decrease the heat
or you have problem with your tags, probably you have defective tags with too much glue
Sep 15, 2011 | Zebra Eltron TLP 2242 Thermal Label...
Do you have a parts manual for a Kenmore front loading washing macnine model number 970-C42062-00?
The model # you gave is not valid.
Look for the silver metal tag usually found on Kenmore washer on the frame when you open the door.
There will be the model # xxx.xxxxxxx
Once located you can go here and using the correct model# get parts and pricing info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Jan 05, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
R they any good
mcdevito75, Tag Heaur, one of the finest watches around, an old company and high end quality watches, Tag Heaur watches very, very good watches, high collector value, also expect a price tag on your tag Heaur watch, as they are not cheap.
Oct 16, 2010 | Tag Heuer Link CJF2114
Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Mar 23, 2009 | Zebra 2746e Thermal Printer
Retail Supplies Logo
380 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
