Question about Music
How do I get the sustain pedal to work on my QRS Pianomation MIDI?
SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Posted on May 15, 2009
  • 4 Answers
SOURCE: Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Posted on Aug 15, 2009
  • 1138 Answers
SOURCE: Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
Posted on Aug 17, 2009
SOURCE: Sustain pedal on Yamaha DGX not working
Hi, I had the same problem, but I have an easy solution. I am trying to connect an FC5 to a Casio CTK-3000. The problem is open vs closed circuit in the pedal and the way that the casio interprets the info. Paulll's fix is correct, but you do not have to use soldering. Simply remove the cover, unscrew the silver screw, and you will notice that the black contraption that holds the two metal strips has one side that pops off. Pop off this side.
Now, notice that the short strip is on top and the long strip is on the bottom. The way the strips bend mean that the circuit is closed when there is no pressure on the pedal. When you press the pedal, the white knob on the long strip pushes the long strip down and breaks the connection with the short strip.
What you need to do now is remove the two strips and slide them back into the black contraption with the long strip on top and the short strip on the bottom. The white knob on the long strip should be facing up. Make sure when you do this that you hook the short strip over that little horizontal black plastic rod so that it will easily contact the long strip when the long strip is pressed down.
By bending the top (long) strip a little, you can make it so that the long strip does not touch the bottom (short) strip in the relaxed position. Make sure that the ends of the strips where the wires join do not touch each other either. You now have an open circuit in the relaxed position, which is what Casio recognizes as NO PEDAL.
Pop the side piece back on the black contraption and screw the black contraption back in place with the silver screw. Set the spring back in place and reattach the 'pedal'. Make sure that there is enough clearance between the top of the white knob and the inside of the pedal so that the circuit remains open in the relaxed position.
Now, if the two strips are NOT touching each other, when you plug it into your Casio, the Casio will not recognize the pedal, which is good. When you push on the pedal, you will close the circuit and the Casio will recognize the pedal.
If you push on the pedal and nothing happens, then the two strips are not contacting each other in the fully pressed position. Take the unit apart and try again.
If the Casio still recognizes the pedal even though you are not pushing on it, then the two strips are contacting each other at any place along their length. Take the unit apart and try again.
Enjoy your new working pedal!
Greg
PS. If you Casio won't work with your computer, there is a fix out there for that too. It involves removing (or renaming) some files that Logitech loads on to your computer when you install a webcam. Weird, but true.
Posted on Jan 27, 2010
SOURCE: Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Posted on May 19, 2011
Midi sound does't stop
I don't have any of that gear, but check that an option like "note on/off" is turned on in the MIDI setup menu on the Juno-D. Also check in Logic that it's midi is setup right. Logic could also be receiving sustain pedal MIDI info from the Juno. Anyway, that's all I got.
Mar 28, 2014 | Roland Juno-D
Hi i have a Casio WK 1200 which has midi in and out and also one assignable jack can i use it for microphone for karaoke singing.
I think the assignable jack is for pedal assignable - Sustain, Soft, Sostenuto or Rhythm Start/Stop ONLY
No, this model does not support Mic input for karaoke singing.
Nov 04, 2013 | Casio Music
How can I get my Roland Dp-10 damper pedal to work with my novation remote sl and axiompro 61 again? I use a mac and logic studio and it has been working fine up until recently.
Look for a setting "pedal polarity" someplace either in the software or in the units.
Read section 2.4.2 of the Axiom manual. Also Appendix E where sustain is documented. The sustain is controller 64. I would use method 1 of the 2.4.2 writeup. You actuate the control (pedal) which arms the unit to accept setup sequence for that particular input.
You want to turn on MIDI output for the sustain pedal. Now remember that a Roland pedal has revese polarity of MOST others and that may needs to be setup. It is NOT clear from the documentation if the Axiom recognizes the reverse sense of the pedal, but it should. It SHOULD sense the pedal is normally closed and when you actuate it sense the change so you can configure it.
Some of the software MAY try to configure the Axiom and ASSUME the pedal is the more common polarity and undo the programming you have done.
Apr 04, 2011 | Roland Dp-10 Damper Pedal-new
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
When i plug in my sustain pedal instead of it sustainin when i step on the pedal it works in reverse so now when i step on the pedal it stops the sustain
Roland requires a pedal that is normally closed, open sustains. MOST pedals work the opposite. SOME pedals you can open and rewire... but not all can be.
Mar 26, 2011 | Roland Juno-D
My P85 digital piano have not a good trasmission with midi cable USB, in particular when press the sustain pedal trasmit a note to pc. Thanks
It is IMPORTANT to realize that the SUSTAIN is NOT attached to a note, but is an independent MIDI message. Hence it is up to the external MIDI device to associate the sustain with whatever notes are still active.
Feb 27, 2011 | Yamaha P85 88Key Portable Digital Piano
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
I want to plug in a sustain pedal to my very old yamaha psr 300 keyboard but there isnt a slot. the only slot it fits into is the headphone slot, but then you get no sound! can I get an adaptor for this?
Sorry to bring the bad news but the PSR300 does NOT have a connection for a sustain pedal.
It will however recognize a MIDI command for sustain so if you had a MIDI sustain pedal that emitted controller 64 code, you could use that.
It is UNLIKELY you would want to do this as such devices are not readily availablle. If you slaved this from another synth that had a sustain pedla capabilty you could play booth together and use the sustain of the other synth.
Dec 26, 2009 | Yamaha Portable Keyboard with 61...
Feb 16, 2009 | Yamaha Full-Size Keyboard
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
