Question about Dodge 2005 Grand Caravan SXT
Heater is not pushing out warm air. Sometimes if I speed up it will make the air turn warm. The coolent is at a great level. AC works great. Heat is not working in the front or the back of the van
    Problem Solver:
  • 8 Answers
I agree with other answer. Thermostat could be stuck open also.
Posted on Mar 08, 2015
    Master:
  • 560 Answers
Check the heater core to see if hot water is passing through it. There should be 2 hoses going to it. One into the core and one out. Check to see if both are hot.
Posted on Nov 11, 2014
Heat and ac blower sound normal but very little air is moving inside the cabin. What can cause this?
Cabin air filter? Blower motor working on all speeds? Critters building nest in heater box
Feb 05, 2016 | AC Cars & Trucks
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Burp cooling system how is this done
When you drain & refill a cooling system air is often traped in places like the heater core. If so the coolant level will appear full before it really is. To burp you need to add coolant till full or just over. Adjust the heater control to MAX heat. This will let full force of water pump to push air out of heater core. Fan speed dose not matter. Next start the motor & let it idle. As it warms up the thermostat will begin to open and close. This is when you should see fluid level drop as trapped air is pushed from system ( add fluid as needed). If this is working right you should fell quite hot air coming from heat vents. If air doesn't seem hot enough adding RPM by pulsing gas pedal should do the trick. And that should do it.
Jul 14, 2013 | 2002 Mazda Protege
Have had thermostat replaced, still runs cold in the heater
air bubbles means head gasket.
how is the coolent level?
are you loosing coolant ?
Mar 23, 2013 | 2002 Pontiac Montana
Why does my heat blow warm air then it turns cold
its VERY likely that your heater core is getting stopped up.
The heater in your car works by circulating hot water from the engine into a copper or aluminum pipe coiled up in the dashboard. The heater/airconditioner's fan blows across it and the hot air comes out of the vents. This is why the heater doesn't work right away when you first start the car. It usually won't work until the hot/cold needle in the gauges is starting to rise up.
If your mechanic recently replaced the thermostat, its possible that there is air in the system which will result in less antifreeze in the car than it should be. If this is not the case, the heater core is probably stopping up and will require expensive replacement if it cannot be flushed clean.
Check to make sure the car is full of antifreeze IN THE RADIATOR, AND THE OVERFLOW JUG. Please be very sure there is NO AIR in the cooling system as well.
Scott
Jan 22, 2013 | 1998 Ford Expedition
2003 kia sorento heater blows warm air only while driving at high speed
Engines can rock on the motor mounts. You probably have a vacuum line that is pinched, cracked, broken,kinked, or unhooked. check the engine compartment lines first. If you have thin plastic vacuum lines, they can kink more easily than rubber lines. If you have been working under the dash (replacing a radio, etc) check your work area in case you have a broken fitting on a vacuum housing or an unhooked line.
Dec 12, 2011 | 2003 Kia Sorento
I have a 2001 expedition 4.6 liter. The air works great but when you turn on the heater it doesnt get warm. air blows out but its not warm. what is the problem? please help
is your engine antifreeze at correct levels is thermostat opening and closeing at correct engine temp theres a little door up inside your air duck that switchs it self when you switch from ac to heat it may be stuck open
Dec 01, 2010 | 2001 Ford Expedition
My heater doesnt work on my 330 bmw .....nothing blows out at all! Is this a quick fix or do I have to take it to the shop, and how would I go about fixing it myself!??? Any suggestions please
does the fan work,if not check fuses,or maybe switch,or fan motor which is unlikley,you need some one you know whos handy to at least think about it after looking at it in the flesh
Oct 28, 2009 | 2003 BMW 5 Series
Heater blowing cold on 2005 Nissan Xterra
I live in Alaska and have had the same problem i just added more coolent to the radiator and it warmed up i installed a block heater and i leaked a bit and the coolent level got low and i would have no heat. I tryed to fill just the coolent resivoir and that dident work so i filled the radiator pumb full and that worked!! Hope this helps.
Nov 17, 2008 | 2006 Nissan Xterra
Dodge 2005 Grand Caravan SXT Logo
132 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
