Question about Whirlpool MH7135XE Microwave Oven
Is it worth repairing or replacing a control/circuit board in this microwave?
The microwave works fine, but the cooktop light over the range burnt out and after replacing the light stays on permanently. I think this means the circuit board was damaged?
    Sergeant:
  • 229 Answers
I agree that the cost of the repair outweighs the cost of replacing the whole MW. It appears that the solid state device that takes the keypress from the keypad to control the light circuit is shorted so the light stays on all the time. Most likely from a lightning surge. Use it the way it is. You will hurt nothing without a light in the socket. My info indicates this is a model from the late 1990's so it is about 15 years old. It is not hard to changeout a microwave. You might need some help lifting it into place. Choose one as similar as possible to the old one.
Posted on Nov 14, 2014
    Master:
  • 560 Answers
It depends on the cost of the repair, You can replace a conventional unit for about $200-$300.00. Unless you can diagnose the issue and repair the item, I'd probably replace the unit, especially if it's an older unit.
Posted on Nov 11, 2014
  • perfectpear Nov 12, 2014
    That's why I'm trying to find out .. what the cost of the repair would be? I've seen several comments about places that repair circuit boards but they all seem outdated (i.e. microwavedisplay.com). I don't know what the replacement cost for the board would be or if I could put it in myself.
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
My microwave is always running
It looks like your model is "GH4184XS##" If so, this sort of symptom is common in cases where the cooktop lights blow.
Several components on the control circuit board can be damaged, and other strange symptoms can occur.
But we see (and repair) this a lot. The problem is on the control board, which we regularly repair for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This failure often occurs when a cooktop bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
If you prefer, you can purchase a new control circuit board from the Pros here, our favorite supplier.
You can look up part number based on your full model number here.
Oct 25, 2012 | Microwave Ovens
The light went out an the turntable won't stop when I close the door...i tried to push clear, but it still turns. I couldn't find my model number on the below pull down, but my model is 721.8001...
721.80019401 (without spaces) is the correct model number.
If it was the cooktop lamp(s) that went out, I would suspect that it shorted, damaging the control circuit board.
We see and repair this problem on a regular basis with our $39.95 repair service.
Or you can order a new control circuit board (part number 6871W1S354A) for $75.80 from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Kenmore 80012 Microwave Oven
Model mh3184xpso whirlpool microwave the vent fan for steam from the stove is humming in the off position. it works on all speeds but it runs real slow on the off position and hums.
Have you recently had a failure with the cooktop lights?
If so, we see (and repair) this a lot. The problem is on the control circuit board, which we regularly repair nationwide by mail for $39.95.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Even if you've not had a recent failure with the lights, i would bet it's a leaky hood fan triac on the control circuit board.
Mar 13, 2011 | Whirlpool MH3184XP Microwave Oven
The cooktop lamps on my Whirlpool MH6130XEQ-1 microwave do not work. Their receptacles receive 70 V AC, no matter whether and how many times the soft switch is pushed.
I just saw this inquiry today, and while you may have already dealt with this, here is my answer, in case it might help you or others:
We see and repair this on a regular basis with our $39.95 service. Details are here.
It's a problem caused when the cooktop lights fail or are removed or inserted with the power still on.
They short internally, and the resulting surge damages the control circuit board.
It can affect fan and oven light operation, keeping them from working or leaving them stuck on.
If you prefer to replace your control circuit board, you can order it (part number 8172054, formerly 4359661) for $168.39 plus
shipping from the Pros here.
moz-screenshot.pngmh6130xeq-1_panel_smaller.jpg?filename=mh6130xeq-1_panel_smaller.jpg&q=786obatqb1684s0931&o=4337&contentlength=75762&downloadid=ebf28cd0ae6c0b1566d991c489678ab1
Nov 14, 2010 | Whirlpool MH6141XK Microwave Oven
No Cooktop Lamps
9a1ba72.jpg You can solder a wire on here to bridge the broken trace. 1 min fix!
Jan 31, 2009 | Whirlpool MH1140XMS Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
Sep 11, 2006 | GE JVM1651 Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
63 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
