Question about Samsung Televison & Video
Is there any way to access the service menu on samsung TV without a remote?
Help
  • Samsung Master
  • 5,476 Answers
No! Most TVs will only fully function with an original remote! Some universal remotes can work but it will be trial And error!
Posted on Nov 11, 2014
techman
  • 3130 Answers
SOURCE: Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
Posted on Nov 07, 2007
SOURCE: GREEN CONVERGENCE IS MOVED,I THINK I CAN FIX FROM SERVICE MENU,CAN SOME ONE TELL ME HOT TO ACCESS IT?SAMSUNG PROJECTION TV HCN 4226W.
1. Go to Picture section
2. Scroll down
3. More menu option appear
4. Then pick 'convergence' on the list
5. push remote right key
Then you're at the convergence menu.
Posted on Mar 02, 2008
SOURCE: access service menu lg rear projection tv
I want enter the convergent net code
Posted on Jul 13, 2009
  • 210 Answers
SOURCE: trying to access the Service menu of samsung dlp
put tv in stand by ( have to be quick ) press i / 5 / vol down then anolog or didgtal on remote the service menu will come up
Posted on Dec 16, 2009
  • 52 Answers
SOURCE: can the service menu for the LG 52sz8d dlp tv be
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Posted on Apr 22, 2010
I need to access the service menu without the remote
You can't enter its service mode, without a remote control. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Samsung LN37A450 LCD TV
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
PLEASE AM UNABLE TO TUNE MY T.V. TO A-B WITHOUT USING MY T.V REMOTE. I URGENTLY NEED HELP PLEASE.
Do your TV has a 'Menu" button on its front panel? If yes, you can enter its menu options, and select the inputs. If there is no such button, you must have a remote control to select inputs.
Jun 06, 2012 | Samsung Televison & Video
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Acessing menu without remote
A) Look for a menu button somewhere on the tv itself .. Usually volume or channel buttons serve as up and down, etc..
OR
B) Go to electronics store and buy a universal remote $10-$20 and program it for your tv.
Aug 15, 2009 | Sharp 32L-S500 TV
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Feb 11, 2009 | Sharp 25N-M100 25" TV
Remote control key sequences.
That sounds like something that would be in a service manual. Now that your tv warranty is expired, you can probably buy the service manual off samsungparts.com. I wouldn't have suggested that if your tv was in warranty, because that procedure would be in the service menu, which only Samsung trained technicians have access to when the product is in warranty. Just remember, if you go in the service menu and mess things up and can't fix it, you would probably need service for the tv.
Jan 09, 2008 | Samsung BP59-00016A Remote Control
Televison & Video Logo
155 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
