I burned a disc of music but doesn't play on my Panasonic CD Stereo System.
I burned a disc of music to play on my CD Player but it won't, other discs do play fine. My burned disc plays on my computer and works fine in my car's cd player. Why won't this burned disc not work in my Panasonic CD Player?
  • 5,499 Answers
Some players are like that! You need to experiment with different makes and speed settings when recording!
Posted on Nov 11, 2014
Why won't a cd disc that I "burned" play on my Panasonic CD Stereo System?
Try cleaning the lazer lens in the Panasonic cd player. Dust can cause it not to read the disk.
Nov 11, 2014 | Audio Players & Recorders
I had bought a regular cd from hmv with music on it & when i put the cd in the cd player,it wont play & reads NO DISC also does not reads the amount of music on the cd,why does it give me this...
1. Check that the disc is free of scratches and dirt or dust. If the disk is dusty, use a soft, lint-free cloth and wipe the disk gently, using straight strokes from the center of the disc to the outer edge.
2. Make sure that you are inserting the disk with the plain, reflective side down.
2. Try listening to another CD (not burned) that you have purchased. If the other cd is giving you the same error message, return the cd player to the store, because it is defective.
3. Ensure that the disc you are using is not a DVD disc. It is easy to confuse the two.
Hope that helps! Good Luck!
Mar 13, 2011 | Panasonic SL-SX420 Personal CD Player
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
I have an HP Pavilion mx704 desktop PC 2005 model, and I can not burn music onto a CD. This computer has a CD burner, and when I start burn of the downloaded song, it says insert disk, I put a blank CD-R...
What OS and burn software are you using? Can you see the music files when you look at the file explorer on the computer (My Computer or Computer in Windows and double click on the optical drive)? Check if the disc has any scratches.
If you see the music listed on the optical disc, check if the disc was finalized. (Again in Windows Computer, right click on the optical drive and it should be an option if the disc hasn't been finalized.)
If there are no files on the CD-R, make certain that the disc isn't being formatted before you try the burn. (Formatting should only be done on R/W discs.)
If the music files are on the optical disc and the disc was finalized, your CD player is not tracking across the disc properly. Try a lens cleaner. It may need repair and I've never successfully repaired a CD drive (the only ones I've had fail were in computers and were cheaper to replace). The mirror and the belt are the most likely places to have issues.
I hope this helps.
Aug 06, 2010 | HP Computers & Internet
Music video
When you burn the videos to a cd or dvd disc make sure it is in one of these formats: Video CD (VCD), DVD, SVCD because thats what video formats that HU plays
Mar 28, 2010 | Phase Linear UDV9010 Car DVD Player
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
CD's play in Media Player but not Home/Car CD player ?
If you are using windows Media Player to burn the cd you have to burn to an audio cd. You can only burn to mp3 cd if your car or home system canread them. Wma audio cannot normally be read by car or home audio. The file format is called WAV
May 14, 2009 | Dell Dimension 3100 PC Desktop
`Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Nov 19, 2007 | Sony RCD-W10 2-Disc CD Recorder
CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Feb 12, 2006 | Panasonic SC-AK29 CD Shelf System
108 people viewed this question
 Grubhead
Grubhead
