Question about Dryers
Switched it on fan working but no light - Dryers
    Master:
  • 477 Answers
A Fan is a Fan, if it is working then why bother with an light, unless it is a fan light like the ones on a ceiling then in that case i would say that it has been wired up wrong
Posted on Nov 11, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Check your wiring diagram - switch in fan may be bad
Fan works, put in new light switch, have power though switch and wire leading to sockets but when put in bulb power is not there any more.
If you switched to a different type of bulb with the new light kit, that could be the problem. Some remotes won't work with CFL bulbs.
Sep 19, 2015 | Hunter 52" Ceiling Fan With Light And...
Why aren't my lights working after i replaced them
check the light wattage and maybe you did not placed it correctly..
Jun 17, 2014 | Dryers
Wiring the fan and light control
You have to run a 3 wire cable to use that sort of switch. I could probably do some illegal wiring to make it work anyways. To cheat make the ground your new neutral wire. Make the old white into a switched wire and the black into the other switched wire. You can wrap red tape on the white wire to make it more legal.
Nov 24, 2013 | AMS Lutron S2-LF Skylark single pole fan...
Motherboard
Does the power supply fan spin up? does the cpu fan spin up? do any of the lights work? does the machine make a beeping noise? Is it plugged into the mains and switched on? is the monitor plugged in and switched on?
Jun 24, 2012 | Matsonic MS9367E Motherboard
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I have a hunter ceiling fan. The motor works fine, but the light blinks on an off rapidly when switched on. The pull chain works but the light does the same thing. Do I need to replace the entire fan?
NO YOU DO NOT !! there is a little black box on inside of fan that controls the lights, its a ( watt governor ). just remove this black box and wire directly to the lights. problem should be fixed !! have a good day !! this is another goverment quick fix.
Oct 30, 2010 | Hunter Ceiling Fan Light Switch Control
Chain to light does not work
Most paddle fans that come with a light kit (or provisions to add one via plug / jack later) provide at least 3 wires (most times 4 though) that will need to be connected to the house wiring. Those wires are:
1) Green, or Green with a Yellow stripe - this is the grounding wire and is connected to the grounded metal junction box or other ground wires.
2)White - this is the neutral wire and is connected to both the fan motor and light fixture.
3)Black - this wire connects to the fan motor. This wire along with the white wire completes a circuit for the fan.
4)Blue - this wire connects to the light fixture. This wire along with the white wire complete a circuit for the light fixture.
Ideally, the junction box in the ceiling has a neutral, ground and both an unswitched power source *and* a switched power source. An unswitched source is always on (regardless of any switch's position) while the switched source is controlled by one or more switch(es) near a door(s). Use a meter or tester to determine which wires are switched (probably black or red) and unswitched (probably black but may be red, too). Label them or orient them in such a way that you'll remember which is which. Turn the power off.
Connect the paddle fan's blue wire to the switched wire, the black wire to the unswitched wire(s), the white wire to the other neutral (most likely white wire(s) and finally, the ground wire to the rest of the ground wire(s). Turn power back on.
Wiring in this way allows the light fixture to be controlled by the wall switch(es) and the fan by the pull chain on the fixture. Turn the wall switch on and pull the chain until the light turns on. You can remove the long chain once the switch turns the light on and off so it is not accidentally shut off at the paddle fan later. Change the fan speed from high to low and eventually off with the chain.
If you only have a switched or unswitched power source in the ceiling, you'll have to connect both the black and blue paddle fan wires to whichever type power you have in the ceiling (switched or unswitched). If you're using a switched sourced, that switch will have to be left on in order for the fan or light to work.
If you have wired in any of these methods already, it could be that the switch for the fixture has failed, and should be replaced with a like-type switch.
I hope this helps!
May 20, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Range hood light failure
Hi bentson,
I'm Harvey the Master Plumber.
Your problem is: Fan works but lights will not. switched bulbs and still lights not working.
You are dealing with a bad light switch. If you have the tools and the talent go for it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 02, 2008 | Kitchen Ranges
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
