Question about HO SD70ACe/Comfort w/PS3 UP
I have a PS-3 MTH train set with DCS remote commander that doesn't move forward or backward but responds to remote commands start up and shutdown, it makes train noises and announcement but I can't ge
I have a PS-3 MTH train set with DCS remote commander that doesn't move forward or backward but responds to remote commands start up and shutdown, it makes train noises and announcement but I can't get it to move. Is there any fix ? Thanks Joe
  • 34 Answers
Just curious but when you move the speed wheel, was the scale speed number on the display increasing? Also, if not working, try the quick speed setting i.e 20 and see if it will respond to the quick speed you set when you depress the speed wheel down. If still no movement, there may be a problem with the motor driver. If it does respond to the quick speed setting then the problem is in the remote with the wheel pickup sensor. Also make sure that there is no broken wire going to the tachometer pickoff on the motor.
Posted on Feb 02, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Try taking the remote apart ...meen ake sure there isnt or hasnt been a corosion problem...clean with alcohol
Posted on Nov 11, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Which command base will work with MTH dcs
You will need to add a TMCC Command Base and the required TIU/TMCC serial interface. This will allow you to control Lionel engines with the DCS remote. Please see page 100 of the DCS Operators Manual fifth edition.
Nov 13, 2014 | Crafts & Hobbies
Tip
How to set timer for shutdown in windows os
step 1: click start menu button<br /> step 2: click on the 'run' button<br /> step 3: in the box that appears,type in the command ''shutdown -t 01"<br /> the computer will start shutting down in 01 seconds<br /> Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value<br /> for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
on Jul 20, 2011 | Computers & Internet
Tip
How to shutdown your computer very fastly in microsoft operating systems.
on Jun 19, 2011 | Computers & Internet
R2 won't move forward on command
Have you checked to make sure his wheels are unlocked? Page 4 of the manual shows you where it is. http://www.hasbro.com/common/instruct/SW_R2-D2_Interactive_Droid.pdf
Feb 17, 2013 | Hasbro Star Wars R2 D2 Interactive...
Lionel Thomas remote chuff off switch does not work
The slot for these switches is too small to allow the slide to move all the way it needs to move. The fix is to carefully file away some of the plastic from the switch slot.
Jul 13, 2017 | Lionel Toys
Tip
Keyboard shortcuts for dialog boxes
To Press
Move forward through tabs. CTRL+TAB
Move backward through tabs. CTRL+SHIFT+TAB
Move forward through options. TAB
Move backward through options. SHIFT+TAB
Carry out the corresponding command or select the corresponding option. ALT+Underlined letter
Carry out the command for the active option or button. ENTER
Select or clear the check box if the active option is a check box. SPACEBAR
Select a button if the active option is a group of option buttons. Arrow keys
Display Help. F1
Display the items in the active list. F4
Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
on Apr 04, 2011 | Computers & Internet
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Sep 01, 2011 | Rio Grande Lionel 34500 Ft Diesel...
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
HO SD70ACe/Comfort w/PS3 UP Logo
126 people viewed this question
Top Mth Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mth Vehicle Part and Accessory Expert? Answer questions, earn points and help others
