My son has a 1986 Toyota 4runner the heater will blow warm air but it wont get hot enough to heat the inside cab.
IT WILL GET WARM BUT NOT HOT.I PUT A NEW THERMOSTAT STILL NOT HOT JUST WARM.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Try replacing the thermostat again....iv had too many "new" ones not work.
Posted on Nov 11, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: Central Electric heat not blowing hot or warm air
Make sure you are in the heat mode. Do you hear the wall thermostat click when you raise and lower the set temp. If not replace thermostst. Clean all filters to start. Does your heat source have a pilot light to start or is the unit located out side. If apilot light make sure itis lit. let's go from there
ddr_2u@charter.ner
Posted on Jan 13, 2009
hardrocko
  • 1476 Answers
SOURCE: heater wont run on hi and doesn't get warm at all
One of two things here. You blew an internal fuse or the heating element is broken. Take your unit apart and check for bad fuses and also check that the heating coil has continuity. Let me know how you make out.
hardrocko
Posted on Feb 07, 2010
  • 102 Answers
SOURCE: new water pump thermostat heat warm get better
Thermostat could be faulty Could be low on antifreeze. Is the thermostat installed correctly? Is it the same stat that the amnufacturers recommends?
Posted on Dec 15, 2010
  • 224 Answers
SOURCE: Heater is not blowing hot air like it use to only
You can try using a compressor and blow gun and cleaning it with the forced air once front to back and back to front. There is no given number of times to do this, I do it until I have clean air going thru both directions. This is the easiest way with out taking the fan apart and man it is a fast repair for sluggish heaters.
Posted on Dec 21, 2010
Why hot air dont blow out of vent?
Probably have a bad Door Airflow control box
Dec 04, 2016 | Toyota Cars & Trucks
Heater in my 2009 Toyota 4Runner id not blowing hot air
its either your heater fuse or your heater core. check your manual and check the fuse first
Jan 04, 2015 | Toyota 4Runner Cars & Trucks
Blows only warm air, not hot
Many of these heaters have four infrared heating bulbs inside, and they do burn out over time, and it doesn't put out as much heat. If you take off the outer case (usually 4 screws hold it on) you'll see the bulbs and will be able to determine which ones are not lit up and need replacement.
Oct 19, 2014 | EDENPURE USA 1000 Black Portable Heater -...
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Why would my fan blow but not blow hot air?
Locate the heater hoses and feel for temperature.Should be warm to the touch.
There may be an external heater control valve next to the firewall that is either vacuum or cable controlled.
the lever on the side opens and closes: warm coolant going into the heater core,inside the cab. If the valve is stuck,no heat.
If the vacuum to the valve is ZERO,it should open.
If the heater control vacuum hose is leaking air,you should get hot air ALL of the time.
people in the winter want heat NOW. Bypass the heater valve,under the hood with a section of copper or plastic tubing.
Even if the heater core is partly plugged up,you will still get some heat.
If the control valve is stuck closed: NO HEAT.
Listen under the dashboard for a hissing sound.That may be the problem for the control valve not opening.(Turn the fan off)
I'll assume this is a late model truck.
Nov 26, 2012 | GMC Sonoma Cars & Trucks
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
The heater in my 2002 dodge dak. 3.9 wont heat,it blows warm air, ichanged thermostat and flushed rad.Someone said try swiching water (heater) hoses.
check heat hoses going into fire wall to heater core should be hot when engine warm solution clogged hoses going to heater core
Oct 14, 2012 | 2002 Dodge Dakota Club Cab
Drained radiator added prestone Radiator flush refilled and started overheating, drained radiator replaced thermostat and now I get no heat from heater,Radiator water is hot
disconnect the heat hoses going into fire wall , put hose into one with pressure and flush as it sounds like it could be bloked in the heater core,the other thing that could be the problem be the hot ,cold switch as it restricts the flow to makes the heater hoter or colder , it might need tlc or replacing as it is manaul not elec
May 08, 2012 | 1995 Toyota 4Runner
TEREX 860 temperature gauge not working engine warm gauge in cool area. Cab heater warm not very hot what is the proplem
if the engine is not reaching operating temp, then the heater is never going to blow warm air. I would start with checking temp of engine, if its not warm enough (180f) I would replace the thermostat
Nov 10, 2010 | Toyota Pickup Cars & Trucks
97 toyota 4runner
Sounds like your heater coil could be clogged. Its a small radiator like device that hot coolant is pumped through to heat the cabin. its very small so clogging is pretty likely.
Oct 22, 2008 | 1986 Toyota Celica
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
