Question about Canon 2525 Copy Machines
Hi.. I have a canon ir2525 copy machine it shows 000202 code on screen please help me.
    New Friend:
  • 24 Answers
When you turn on the copier the scanner should move out of home position and the light come on. If the scanner moves you have a bad sensor. If the scanner does not move something is binding it up or the motor is bad. Power off the copier, take off the glass and try move it gently by hand, look to see what is binding it up.
Oil the rails, check the set screw is tight on the shaft on the right side.
While you have the glass off check the sensor. Look inside toward the left rear and see if it is damaged or knocked loose.
Posted on Nov 12, 2014
Canon ir2525 error E000202 how to solve it
First contact canon for code clarification and then deal with it. How can you fix without knowing what the problem is?
Sep 07, 2017 | Canon Office Equipment & Supplies
How do i clear e000000 error on a canon ir2525 copier?
hi. you need to enter in service mode
in the control panel do the next key secuence:
press adittionl function
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
May 01, 2017 | Canon Office Equipment & Supplies
Ir2525 error e000002
E000002-0000 what you need to do is just resetting. On your machine, Press * 28 * on your machine . 2. Select Err. 3. Select Clear then press O.K 5. Turn your machine off for 1 minute and turn it on again. The error code will not be there again and your machine will be function normal
Mr. Ashua James
Jan 19, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
ERROR CODE E000202-0002
Clear me about error code 000202 and send me the solution
Dec 19, 2012 | Canon imageRUNNER 3030 Black and White...
All service code for Canon ir2525
canon ir 2525 errer coad is E000002 how can reset the machine
Jul 31, 2012 | Canon imageRUNNER 2525 AllInOne Laser...
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Dec 16, 2008 | Canon MF8180C Color Laser MFC Printer
Canon 2525 Copy Machines Logo
79 people viewed this question
old marine
old marine
