Canon ir 2420 shows paper jam when there isnt any
After blowing off some dust and toner debris,it says paper jam i have tried to clean out the sensors but still pls help
  • 63 Answers
HI,
This is happen due to printer feeder problem.... pls check feeder and clean carefully.
Thanks,
Posted on Nov 12, 2014
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
Hi, I have several jams in a ir canon 5000, in the vertical path with delay in the PS24 sensor. I exchanged that sensor getting the same result. Someone have had the same problem?
Doubt motor, suspect slipping paper feed roller in area just before ps24 area, or slipping clutch or obstruction in paper path. Ensure your using fresh paper, not old as it curls and causes issues. Rare is it a motor fail, especially if issue is sometimes rather than everytime. Clean clean is usally the fix or most paper path problems. Paper dust often makes rollers and feed tires slip rather than grip. Cheaper paper gives off more paper dust and causes more wear. Slightly damp rag just with water on rubber rollers is the best tool.Good Luck.
Jun 10, 2016 | Canon Service Manual For Ir 5000
How to do remove roll from sheet path?
Its malfunction of sheet path paper sensor due to dust, don't open any thing just high pressure air pump required(ex bicycle pump)blow on sheet paper path sensor located just left above of paper roll path(look black "U" shaped, blow air in it.. check it will get resolved... Reason:the IR paper sensor shell having very small path(holes both side) to run the IR beam to other side, if the dust accumulate on IR diode the rays unable to travel to other side, result malfunction of sensor, if we blow presser air on it, dust will clean & sensor will work normally.. Its not funny remedy..it will work try it...
Sep 02, 2011 | HP DESIGNJET T770 Printer
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
I can't get my brother printer to print photos Keeps saying paper jam even though no paper jam
Sep 23, 2010 | Brother MFC-685cw InkJet Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon mp145 shows paper jam..there's no paper in it..how to reset it?
there may be dust or some small piece of paper stuck. Try blowing in air in there to see if anything gets loose/out
Dec 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
70 people viewed this question
k24674
