Question about Samsung Refrigerators
How do I replace DA97-08118n?
I am trying to replace the electronic panel for the water and ice depenser
  • Samsung Master
  • 744 Answers
Hello Fred;
My name is Peter. I am a retired field service refrigeration technician.
Samsung has a lot of different models.
Send me the model number. It should be on a label on the wall of your fresh food section
Posted on Nov 11, 2014
Testimonial: "Peter, I was able to remove the panel, all is good. Thanks Fred"
SolutionGuy
  • 331 Answers
SOURCE: PSS26LSRD
Apazm1, unfortunately your main control board is the culprit for your woes. The part number is WR55X10552 and retails for ~$115.00. There's good news, though! It's readily available, (all the appliance parts retailers have them) AND they are easy to install. After you have the new part in hand, open the box and read the instructions CAREFULLY. These boards have been modified from the original OEM's and work on all fridges like yours. UNPLUG YOUR FRIDGE! Pull it away from the wall, locate the aluminum panel that covers the computer and remove it (4 screws). The board is held in place by 4 white clip tabs. They poke through the board at (roughly) the 4 corners of it. Look closely at these with a flashlight... you'll see where you need to squeeze them with a pair of needle nose pliers to release them (squeeze the clip and pull that area of the board at the same time). Then remove all the connectors from the board. Now snap the new board into place and reconnect all the wires. This is where you need to pay attention to the instruction sheet! Look out for that white "jumper" in "pin #2"... if you don't get this right your fridge won't work right. Here's the reason I know it's the main board and not the board behind the dispenser area... the dispenser board is low voltage, the main board is high voltage. The dispenser board only sends a signal to the main board. From there, the main translates this input into a high voltage command for the component you have selected (water, ice crushed, cubed, etc...) The components that aren't working on your fridge are high (120) voltage parts controlled by the main board... ergo, failed main board. Hope this helps! Let us know how it goes, will ya?
Posted on Aug 23, 2007
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
  • 37 Answers
SOURCE: hotpoint refrig makes ice but no water will come out
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
SOURCE: ice maker and water dispenser front panel lost power
My door dispenser loses power and I can uplug fridge and plug back in and I have power, then after a few minutes the power goes off again.
Posted on Dec 27, 2009
SOURCE: Maytag MFI2266AE ice and water dispenser buttons not working
did you ever figure out your fridge?
I am having the same problem...
Posted on Oct 18, 2010
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Nov 27, 2014 | Refrigerators
I have mold forming on the ice depenser that's next to the water depenser. Is there a way to remove that piece so I can clean it?
with out seeing the brand or model i have to be pretty generic but their should be a removable grate so drips when dispensing ice or water that can be easily lifted and wiped out, if not place a paper towel at bottom of dispenser asm. to catch drips
Jul 23, 2011 | Refrigerators
The ice and water do noit depense and the IWD LIGHT SAYS OFF
Press and hold super and freezer buttons at the same time for five seconds.
Mar 08, 2011 | Bosch Refrigerators
Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator by itself activates the water or ice dispensing
could be the water valve or water switch (depense switch)
Apr 01, 2009 | Refrigerators
I have a Frigidaire refrigerator Model FRS6L9EFSS0
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or crushed ice , or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Ice tray freezing
the water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Mar 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Hotpoint refrig makes ice but no water will come out
Dec 28, 2008 | Whirlpool GD2SHGX Refrigerator
Water stop depensing ice work but no water
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
http://www.fixya.com/support/t1247133-no_water
Copy paste link.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
93 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
