Question about Casio FX-260 Solar Scientific Calculator, 10-Digit x Two-Line LCD Display
<!-- from fixya rte -->How do I clear "DEG" from display? - Casio FX-260 Solar Scientific Calculator, 10-Digit x Two-Line LCD Display
  • 59 Answers
You can switch between Rads/Deg/Grads. Deg is the one you want to use. So, to answer your question, the "DEG" is suppose to be there so that you know what mode you are using. If you don't have the manual, here it is:
http://support.casio.com/pdf/004/fx82SOLAR_E.pdf
Posted on Nov 11, 2014
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
Machine show an error E000002 Model iR2530 Canon Imagerunner
these means the reading of the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has indicated 100
deg C.
2.The reading of the main thermistor is less than 150 deg C
continuously for 400 msec 1.3 sec after it has indicated 140
deg C.
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the
power.
TO ENTER SERVICE MODE:
press *
press 2
press 8
press *
If you cant clear the error code these means that you need to replace fixing heater.
Hope that helps!
Aug 19, 2010 | Canon Office Equipment & Supplies
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
How do I reset the calculator after installing new
[OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
To clear memory M1 : Store 0 in 1
0 [STO] 1 clears M1
0[STO] 2 clears m2
0 [STO] 3 clears M2
Feb 03, 2010 | Texas Instruments TI-30XA Calculator
How do I convert from decimal degrees to degrees, minutes, and seconds?
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Degrees seconds and minutes
Sorry, text was posted as clarification request. Here it is
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Display reads DEG on top with L under when I turn on. will not clear
When you turrn calculator ON the angle unit is reset to Degree and the DEG indicator is displayed. I do not know what the L is for, but you can get rid of the DEG indicator during calculator operation only if you change angle unit to RADians or GRAdes. However it will be replaced by the indicator for the new angle unit. After the power down, the unit will be back to the default DEG. What can you do about that?
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-30XA Calculator
Help!!
You need to be in the degree mode. To do this push the mode button on the calculator (mine is located near the directional keys). Go down three rows to where it displays RAD DEG. Move your cursor (which is blinking) to DEG and press enter. This will highlight the DEG mode press your 2nd then CLEAR button to Quit back to the main screen.
Oct 10, 2007 | Texas Instruments TI-81 Calculator
Casio FX-260 Solar Scientific Calculator, 10-Digit x Two-Line LCD Display Logo
185 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
