Question about Toys
We are trying to bleed brakes on CASE 426C Backhoe. But for some reason it is not working. What can I do to get it right?
Our backhoe didn't have brakes, we have done all that and now are trying to get the brakes bled. But the brakes are not working properly now. It is acting like it is not getting the mineral oil that the brakes need.
    Sergeant:
  • 311 Answers
Probably blew the master cylinder when you lost the brakes.
When an older vehicle's pedal goes ALL the way to the floorboards,the master cylinder "sees" crud at the end it never touched B-4.The seals have been damaged. Possible to get a kit to fix it but don't. Get a rbld. master and start over. Done.
Posted on Nov 12, 2014
5 Suggested Answers
udesh99
  • 97 Answers
SOURCE: Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
Posted on Sep 23, 2009
rynanlimpiad
  • 36 Answers
SOURCE: 580b case backhoe trackter will go forward somtime
check the connection of your control circuit
Posted on Apr 06, 2010
SOURCE: Case 580C model 33 backhoe - transmission problems
good time to go ahead and change fluid,dexron 3 and clean screen filter.holds 8 quarts..check ur manual for correct installation of fluid. 3 quts.strt engine 5 more in filler tube
Posted on Nov 03, 2010
wiedmerf
  • 18 Answers
SOURCE: i need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Posted on Feb 28, 2012
Can't swing the backhoe arm left or right with the controls
The travel lock is either in place keeping it from moving in transport or there is something wrong with the hydraulics. Look for a push button release. The other thing is the stabilizers have to be engaged
Jul 21, 2014 | Jcb Bruder JCB Loader Backhoe
How to bleed brakes on a 580se case backhoe
Start at the wheel that is farthest away and work forward.
Oct 11, 2012 | Cars & Trucks
I need to know where the bleeding screw for brakes on jcb214e backhoe
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Backhoe wiil not swing all the way to the right
Just a shot in the dark but there could be some debris in the sequence valve. Worth a look at? Good Luck
Jul 26, 2010 | Digital Data Communications D149283 Case...
Caterpillar 426c Problem will not shift Into forward and Reverse
It sound like it could be a problem with FNR shift lever, is the harness running to the back still attached?
Mar 06, 2010 | Caterpillar Backhoe Tractor
I have an old Ford 550 digger clutch failure
if its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
Jul 19, 2009 | San d Digger
Jun 14, 2009 | Bruder Jcb 4CX Loader
Toys Logo
115 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
