Question about Car Audio & Video
Can I use a inverter for boost for a car amp?
  • tjanzer Nov 11, 2014
    Can you please give me a little more information. Where do you plan on plugging in the inverter?
  • 1,388 Answers
Yeah, it can be done. Instead of the booster being 12 volt, you'll be using a 120 volt booster. Won't make a difference on output of booster, 4 amp and up, whether it's 12 volt or 120 volt power input, you'll just be using more power from your car battery. Be sure you've a good charging system.
Posted on Nov 11, 2014
I have a power pack inverter that is not producing enough cranking power to boost a car
what size inverter/power pack most of the power pack are bought under rated for their use -a booster that can start a 4 cylinder coupe may not be enough to start a 6 cylinder pick up --
Aug 16, 2016 | Inverter Electronics - Others
Car will start then shortly after it will only start with a boost
You should not be boosting what may be a dead battery
That is an unsafe practice
Have battery tested & or replaced,then remove inspect
& clean both ends of cables
If it just clicks then with new battery you have a bad starter
solenoid
Nov 24, 2012 | Cars & Trucks
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apr 27, 2012 | Clarion APX280M 2-Channel Car Amp
Need to know the output power from my cigarette lighter port
Hi, you have a 15 amp fuse to run all 3 sockets. Total peak power available without burning the fuse is 15x12=180 watts peak. Please let me know if you have more questions.
May 23, 2011 | 2006 Honda Accord
With 13.3 volts dc input only putting out 94 volts ac
AT 10.64 AMPS THIS WOULD EQUAL 1000 WATTS BECAUSE VOLTS TIMES AMPS IS EQUAL TO WATTS.
There may be a regulator that boosts the voltage when the inverter is in use. you might check in line voltage while in use and see what you get. Operating amperage should be around 10amps.
good luck and feel free to reply and vote. Joe
Feb 16, 2011 | Duracell Portable Inverter 1000 Watts
84 corvette wont start without battery boost.... brand new battery installed & no change , the radio, horn , etc is good the car just wont start with a boost
It might be the starter, if it gets too much use the armature might be too weak and need extra Amps to get it to work right.
Jul 20, 2010 | 1984 Chevrolet Corvette
Flat battery only done 10000 kms nothing left on it wont take charge completely dead cannot get same battery n70zz is closest but it is only 670 amps not 800 amps
The 670 amps will work, but will probably not last very long. It wont hurt anything except the battery itself. Make sure the cables polarity is connected right. A note on how to boost a car safely: ALWAYS START THE CAR FIRST THAT IS DOING THE BOOSTING. This ensure no computer damage will result on either car. Good luck.
Nov 25, 2009 | 2009 Dodge Nitro
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Bass boost/Gain
Both the bass boost and the gain generally do the same thing, except the bass boost is essentially "additional gain" at a particular frequency (in this case, 45Hz). I would suggest lowering the bass boost (10?) and adjust the gain. Honestly, you may have to play around with both settings until you find a happy medium. There is going to be a maximum the amp can provide no matter how you get there. Hope that helps!
Mar 03, 2008 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
