Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
Can i run a english 3 phase compressor on french 3 phase
I have no wiring diagrams can you help
  • Tommi Stephenson Nov 11, 2014
    I have no switch boxes with this compressor what do i require
    if each phase is 230 how is 3 phase 400v
  • 59 Answers
I've done it the other way around. A European motor on North American system. The voltage slightly varies and they are 50hz instead of our 60hz. It will just run a little faster/slower than it should. If that is not an issue you should be fine. It probably wouldn't hurt to double check with a qualified electrical contractor in your area.
Posted on Nov 11, 2014
    Top Expert:
  • 21,456 Answers
In the UK we have 415V 3 phase. In France it is rated at 400V. I don't expect any issues.
3 Suggested Answers
  • 52 Answers
SOURCE: Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Posted on Mar 10, 2009
  • 5 Answers
SOURCE: I need to build a single phase to three phase
You will need a rotary converter for this, or a single phase motor. A three phase motor absolutely cannot be made to run on single phase otherwise.
Posted on Jul 18, 2009
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
How to wire 3 phase compressor
depends if motor is wired in star or delta configeration as this determines strapping links in motor terminal box. check voltage for your country on motor data plate and this will tell you the configeration
Oct 21, 2012 | Clarke Air Tools & Compressors
Ajax 5hp air compressor wiring diagram Problems
If you're running 3 phase, swap 2 infeed wires. If you're running single phase, look in the wiring diagram in the motor head for the wires to move.
Jan 31, 2012 | Air Tools & Compressors
Need wiring diagram
Mike I do not have a wiring diagram. If you let me know what you need maybe I can help.
Dec 21, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
UNIT WILL NOT RUN WIRING DIAGRAM IS DAMAGED SO REPAIR PERSON CANNOT FIGURE IT OUT
a good service tech dont need a diagram he will just know how to do it. took me around 2 years before i could rewire a unit . you need power to certain things and you just go from there
ie: you need power to blower. you need power to transformer need secondary voltage from transformer low voltage makes the switches for things to come on or off. the compressor and starting for it has to be right or it wont run contactor has to be wired right. run cap has to be the right mfd and wired right are you working on something thats 230 volt single phase or 3 phase
need more info to help you
Mar 02, 2011 | Heating & Cooling
Wiring diagram for single phase two pole 2.5 HP induction motor.
all you have to do is (a) open the connection box of the motor look for the two wires of the starting or running coil, inverse only one coil wire.(a) If there is no centrifugal switch in the rotor, try this it might help open the motor both end,change the direction of the shaft ,which i mean pulley side goes to fan side and fan side goes to pulley side and tighten all bolts.
Sep 11, 2009 | Air Tools & Compressors
Carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Dec 22, 2007 | Carrier 38CKC036 Air Conditioner
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
90 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
