Question about Genius EasyPen M406
My Genius EasyPen M406 pen pressure does not work with Photoshop CS6
The pen on my Samsung Galaxy tab 3 only works sporadically. ..... it'll start recognising threw pen when it's about 2 inches away from the tablet...... there are some spots. .....s note mainly. ..... that...
you mean galaxy note 3 .first be sure the pen has a nib in it not a hole where one has fallen out. then it is about 1/16th or so outof the pen and rounded next try replacing the pen nib your phone came with a packet of replacements. they pull out and are snapped back in. Last and for sure , there is actually a battery inside the pen if it is old and weak you will have to get another pen say from ebay (best price) but before you do go to phone store and use one of theirs to test . if you have the same problem and only certain spots do not work on the screen then your digitizer screen is in need of replacement. also another ebay cheapest item. but whatever it turns out to be it is fixable. come back if you need advice will check every couple weeks.
So pen has nib , or nib needs replacement,pen has weak battery and need replacement or digitizer needs replacement. all solutions are under 100 dollars most under 50 . no nibs or bad nibs under 15.
Dec 23, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Something happened to where when i use the pen there is this area on the screen that will not allow the pen to touch that area of the screen or go near it, it just skips it, why?
This seems to be a common problem with this Toshiba. I squeeze the molding around the screen near the areas that the touch screen is not working. It usually happends in long blocks that don't respond to the pen.Press along the top sides and bottom running along all the edges with pressure. You may have to work with it a few times but it seems the fix mine for a while.. hope this helps
Oct 02, 2010 | Toshiba Portege 3500 Tablet PC
Tablet pc pen isnt working its moves around when i put hte pen to the screen but its like theres no pressure it wont click
A common problem with touch screens on Palm Pilots is contamination getting under the edge causing pressure that fools the screen to thinking there is pressure under the lip of the bezel. There MAY be a similar thing with your tablet PC.
Jan 09, 2010 | Gateway M275 Tablet PC
My pen doesn't work on my tablet pc. It suddenly stopped working
Does your tablet have an LED to indicate it's being powered? If so, it must be the pen.
Does your pen have an internal battery? If so, it's time to replace it.
Aug 21, 2009 | Toshiba DIGITAL TABLET PC PEN FOR PORTEGE...
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
How to use the pen
Using the pen is quite simple.
You extract it from its storage space and use it as a mouse, left clicking it as you would a mouse.
By pressing the tip of the pen on an area on desktop or on an application window and maintaining the pressure for a short while, you activate the context menus (the equivalent of a right click.)
On the Windows task bar (for Windows XP) there is a small icon near the start button that shows a pen pointing outside: that is the input panel. Click the icon with a mouse or your pen, and an input area opens. In that area you write with the pen (writing Pad) or enter letters and symbols one at a time (Character Pad) or use a virtual keyboard.
Under the red X that closes the input panel there is a small gear. C;ick the gear with the pen or a mouse to configure the settings.
Your pen may have an eraser at the rear end and/OR on the side. It is used to erase characters or whole sentences.
To actually record (write) what you enter with the pen you must have a text-editing application open and running.
Whenever you approach the pen to the screen near a text-area (search area of IE or other compatible applications) a small icon appears to be clicked to enter text. This happens is you select UNDOCK in the input panel configuration.
This should get you started with the pen. Try these steps, and if you have any other questions post them as comments to this thread and it will be my pleasure to answer them.
Nov 30, 2008 | Toshiba Portege 3505 Tablet PC
Pen doesn't work
have u tried re-installing the driver... if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver... after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working... One more thing does ur monitor support it???
Aug 30, 2008 | Eaton 30311 Tablet PC
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Jul 04, 2008 | Averatec 3500T60 Tablet PC
Gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Sep 30, 2007 | Gateway M275 Tablet PC
Genius EasyPen M406 Logo
70 people viewed this question
Top Genius Tablets & eReaders Experts
Are you a Genius Tablet and eReader Expert? Answer questions, earn points and help others
