Question about Envizen Digital Duo Box Pro ED8850B Portable DVD Player - 7in. Display
How can I increase the output volume. The sound output is barely audible.
Very low sound output volume, especially when playing DVD's made on my my VCR's.
How do I improve the volume on recorded TV shows?
  • If you record from an outside source, turn up the source (e.g.digital receiver) volume. If recording sound from a VCR's own tuner, tape path, especially the drum(once you open the cover)and linear voice recorder post (to the right after the drum)must be cleaned. Get instructions from the web how to do the cleaning, otherwise you may damage the machine. Switch to hi-fi track if you have one and adjust the tracking.
Mar 04, 2015 | Televison & Video
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Low volume on created DVD
Unlike ripping CDs, ripping DVDs poses many challenges for the average user.
Because you need to get audio and video and need to get them synced correctly problems with the final version frequently arise.
One common problem is that the volume is too low.
The solution might seem to be to simply turn up the speakers, but the sound of a low-volume movie cranked up can crackle or distort. Instead, you increase your DVD rip volume by changing it before you begin the rip process.
Increase DVD rip volume with iSofter DVD Rip (see Below).
http://www.dvd-tool.com/dvd-ripper/faq.html
With this program, a window called "Input Settings" allows you to control the volume before you begin. After the DVD is in the computer, you just use the "Volume" slider to increase the output volume. As of November 2010, the program costs $34.95.
Try Aimersoft DVD Ripper (see Below).
http://www.youtubetoipod.biz/software/aimersoft-dvd-ripper.html
After inserting the disc, you simply click "Load DVD" and wait for it to load
(this could take a few minutes).
The "Settings" button presents a volume slider similar to iSofter's.
Push it to the right to increase the output volume.
As of November 2010, the program costs $35.
The free dvd::rip program offers the most customizable settings for the advanced user
(see Below).
http://www.exit1.org/dvdrip/
Not only can you increase the output volume with a volume slider, you can also compress the sound as well.
This is useful for movies with both loud and quiet parts (such as action movies). It reduces the volume difference so you don't have to reach for the remote every five minutes.
Jun 27, 2013 | Corel 9900-65295-00 Pinnacle Studio 16...
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Televison & Video
Very weak sound on television from dvd. player recently bought. It is a Silvercest KH 6524 player and some official dvd discs.. Even using maximum volume of my t.v. , a flatscreen Samsung and my...
Some brand name of the DVD player.Some brand name DVD player,u must used it own DVD player remote to turn on the volume higer or lower to get it up or lower on the movie DVD discs or any kind of DVD discs are playing.The tv dosen't control the output volume of the movie,if the function require the DVD player remote to do it.Check ur DVD player remote see if u have a volume control buttons + - used those buttons on the DVD remote control u will control the volume of the movie DVD disc it is playing on the DVD player.
Aug 09, 2011 | Televison & Video
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Aug 10, 2010 | Sony VAIO FR130 Notebook
Low Sound
First of all what model your keyboard? Posible couse of audible sound is came from the volume control. Replace the volume control or contact an authorize service center on your location.
Jun 08, 2008 | Yamaha Full-Size Keyboard
Sound
The DVD player has a separate volume control - make sure the DVD player's remote volume is turned up as well as the TV's.
May 29, 2008 | Philips Magnavox MWD7006 DVD Player
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Envizen Digital Duo Box Pro ED8850B Portable DVD Player - 7in. Display Logo
54 people viewed this question
Top Envizen Digital Televison & Video Experts
L Pfaff
L Pfaff
Tom Chichester
Ravi
Are you an Envizen Digital Televison and Video Expert? Answer questions, earn points and help others
