Question about Sewing Machines
I have a singer 247 I broke the needle and have replaced it . Now the bobbin will not turn I have taken it apart and still doesn't work if you could help me fix it I would appreciate it
    New Friend:
    Problem Solver:
  • 7 Answers
Most likely the needle was broken when a piece of cloth was under the machine right , this means that the needle was slightly bent while it went down to pick up the lower thread , in most of these cases it damaged something fornm the bottom spool.....better check carefullyfor marks and VERY genrly with a new needle in place utrn by hand and see feel where it gets stuck...then replace part or bring to shop to fix ...
Posted on Nov 11, 2014
SOURCE: bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Posted on Nov 09, 2008
SOURCE: I need to load the bobbin for my singer 247, I have no manual
I am a veteran seamstress and I may be able to help you. it sounds as though you just have the wrong needle in the machine or the needle is in backwards.. Machine needles are different lengths according to what machine it is. The needle could also be dull on the point. Try this and see if it helps. Also your local sew shop can help you no charge if you just go in and talk with them. The techs enjoy helping for the most part I have discovered.
Posted on Jan 08, 2009
louislevel_2
  • 374 Answers
SOURCE: thread from the needle wraps around the bobbin case and knots
hi! there,
wrong set up made this thing goes wrong,well
its good things to go to internet, on address
type www.youtube.com type on search
box type "sewing macnine" there some
instruction follow specielly set thread and
bobbins and some otrhe sewing feature that
you can learn.have a nice day dont forget to
rate me, thank's
Posted on Apr 10, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
SOURCE: Threading Singer 247 bobbin, no manual
Slot A looks like a groove in the front of the bobbin housing just pull the thread to the right and then to the left to get it into groove A, groove B is to the left of A when you pull it into A it will slip into B. You then just pull the thread forward and you are good to go. I hope this makes sense. I can try to take a picture of mine and see if I can get a clear picture if you still need help.
Posted on Aug 01, 2009
I have a singer sewing machine 247 . I broke the needle and have replaced it now the bobbin will not turn.
CHANGE THE NEEDLE. TAKE OUT ALL OF THE BOBBIN CASING. CLEAN IT AND PUT ONE DROP OF OIL ON THE RACE (THE INDENT AREA THAT EVERYTHING RIDES ON AND CAN'T BE REMOVED). LOOK FOR A BROKEN NEEDLE PART AND THREAD AND ANYTHING THAT SHOULDN'T BE THERE. PUT EVERYTHING BACK. TURN THE HAND WHEEL TOWARDS YOU AND OBSERVE IF THERE IS ANYTHING TOUCHING THE NEEDLE. IF THERE IS THEN THAT WILL NEED TO BE FIXED.
Nov 11, 2014 | Sewing Machines
Singer 513 bobbin thread doesn't feed
the machine may need to be serviced to see if there is some adjustment
needed or see if it's a timing problem.
Jan 11, 2013 | Singer Sewing Machines
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Janome 1600p-DBX is not taking the bobbin
have you checked to see if the needle is inserted correctly into
the needle clamp,,all the way up into the needle clamp
& that the needle is turned the right way
also check to make sure the bobbin is inserted correctly into the
bobbin case.
if you have checked for this then the following is possible
it's very possible that when you broke the needle that it caused
the machine to jump time, & it would have to be taken to a sewing
machine shop to be retimed.
Aug 01, 2012 | Janome 1600P-DB Mechanical Sewing Machine
My singer 247 stopped picking up the bobbin thread.
rethread the machine top & bobbin
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw
if these suggestion don't help then the machine needs to be checked
to see if it's out of time
Jun 11, 2012 | Sewing Machines
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
Looking for bobbin case for singer 3270c I see lots that look like the one I have but none of the numbers they list match mine... Also the machine is bunching up the tread and my bobbin case is broke so...
check with these 2 websites for the part ,,
sewingpartsonline.com or sewvacdoctor.com
it's possible the bobbin case could be a problem, I have 2 sewing machine & if one of them had a broken bobbin case I would replace it
have you tried a new needle
also check the thread take up lever, if the thread comes off of it, that can jam up the machine as well, I've had that happen before
also keep under the needle plate area clean of lint or loose threads & also the bobbin area
Aug 14, 2011 | Singer 3270 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
