Question about Leisure Cookmaster CM101NR
I am asking for a thermocoupling for my grill on a leisure cm101nr
My igniter doesn't click when push it in
order a new piezoelectric sparker by model number.
Jul 28, 2016 | Leisure Cookmaster CM101NR
How do I change the glass lid on my cooker
Buy one direct. I am guessing it has a straight forward screw off hinge. Nice range!
Spares for Leisure Range Cookers Official UK website
Jan 29, 2016 | Leisure Cookmaster CM101NR
Glass lid?
These are tricky, first remove all burners trivets knobs etc so there is nothing at all left on the glass top then you will need two small screwdrivers gently using them like tyre levers work around the edge and it will usually just lift off, when replacing it make sure that everything is lined up properly.
May 06, 2014 | Leisure Cookmaster CM101NR
Oven and clock not working
Bake relais inoperative. Replace clock. ( EOC)
Mar 17, 2013 | Leisure Cookmaster CM101NR
Leisure Laureat 2 refitting grill handles
This is the wrong category for this problem.
Apr 24, 2012 | Cars & Trucks
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Our New World gas oven is just on two years old (i think) when we use the grill it keeps clicking and then it just shuts itself off as though there is no gas getting to it. The pilot light will continue...
If the grill is clicking because you are holding the ignition button, which I'm asuming you are because the grill will not light then the thermocouple on the grill is broken.
goto www.espares.co.uk but unfortunately you'll have to ask them if they have any grill thermocouples for this model as I can't find them anymore only thermocouples for the oven.
Nov 08, 2009 | New World 50GSO Gas Kitchen Range
Need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Leisure Cookmaster CM101NR Logo
152 people viewed this question
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
