SOURCE: ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
SOURCE: problem
If you can boot to safe mode, try doing a restore.
When you turn on the system, just past the POST (before windows loads), hit the F8 key to get the menu between normal boot and safe mode.
When prompted, select SAFE MODE. Don't select safe mode with command prompt, or with networking. Just SAFE MODE.
Use the arrow keys to select SAFE MODE. If you need to log in, do so and proceed to launch windows.
Windows should launch in Safe mode. If it does, proceed to click on START, ALL PROGRAMS, ACCESSORIES, SYSTEM TOOLS, SYSTEM RESTORE.
Select RESTORE MY COMPUTER TO AN EARLIER TIME. Click on NEXT. If you can, select a BOLD date preferably before your issue. Click NEXT. System will load some files, reboot and reload.
If you can't get to safe mode, there may be other problems holding your system up. Did you load anything prior to the messages?
SOURCE: IBM ThinkPad T41 boot-up problem
Hello, enter BIOS (by pressing "Delete")and find there restore default. If you drop it you need check inside laptop of connections components. Check Cpu or Ram.
SOURCE: IBM r52 thinkpad laptop hdd compatibility issue
Download Hiren CD .. format the hDD and install the OS Freashly
SOURCE: fan error on ibm thinkpad
take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
