Washer has something stuck in pump how do I get to the pump of crosley cfw4700 ( crosley front load)
My daughter wears bobby pins in her hair ...they get in the washer via left in pockets etc... I had an lg for 12 years... No prob there's a drain trap I could clean.... Crosley has none... How do I get to the pump ... 200.00 service cals for this is not feasible ... I hate this machine!!!!
    Master:
  • 388 Answers
Here are some parts diagrams. Hopefully they will be of some help.
CROSLEY Washer Parts Model CFW4700LB0
Posted on Dec 01, 2014
3 Suggested Answers
  • 2468 Answers
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
  • 1531 Answers
SOURCE: front load crosley washer-door is
Use a wet dry shop vac and attach it to the end of the drain hose and remove all the water this will unlock the door.then you need to look at the drain pump and look for any obstructions that may be blocking the flow of water or stopping the impellar wheel.
Posted on Nov 13, 2010
WATER WILL NOT DRAIN OUT ERROR 21
you have blockage in the drain system-start with the drain trap-if that doesn't do it check the pump-which can get coins, bobby pins, and other stuff stuck in it-cheers Denny
Oct 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
Gltf2940fs1
Oct 26, 2013 | Frigidaire ATF6000ES Front Load Washer
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pump.eg.bobby pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer won't completely drain
Their is a little basket inside the tub to pump hose.
I bet it has something in it. Your MANUAL
Aug 01, 2010 | Frigidaire GLTF2940ES Front Load Washer
WASHER NOT DRAINING on the time indicator the letters nd are displayed and the washer is not completing the wash. water is still in machine
I suspect that something is stuck in the pump. The code is telling you what you already know - there is a drain problem :) I have found many a bobby pin or underwire in there! Best way to drain the machine, in my experience, is to use a shop vac and **** through the drain hose. Good luck!
Apr 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
My front loader washer door will not open a lock symbol is being displayed tryed unplugging did not work
there is a chance that there is something stuck inside the drain pump.use a shop vac attach it to the end of the drain hose remove all the water.unplug the unit and plug it back in this should unlock the door. check the drain pump for foregin objects such as small nails bobby pins,drill bits anything that could stop the impellar wheel from turning.if there is nothing in it then you might have a bad drain pump.
Sep 21, 2009 | Samsung WF328AA Front Load Washer
Washer stops at rinse cycle
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
Washer whines any time the agitator is moving or spinning, not while filling, etc. What might this be? I live in the middle of nowhere and my appliance repair man has died of old age. Literally.
We took the housing off the washer and started the machine, albeit carefully, and followed the squeal. Sounded like the water pump thingy in the front. Took that off from the machine but still connected to the hoses and the squeal stopped. Dipped and drained machine, removed water pump thingy and looked inside. Found a really beat up hairpin/bobby pin lodged inside! (I have two teen daughters at home) Removed pin, put back together, and wah-lah, a few hundred dollar miracle, no squeal!
Nov 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
