Question about Microwave Ovens
My microwave is crumbling away in the back corner is it still ok to use?
In one of the back corners of my microwave there is a split and grey/black bits are crumbling out of the split. is it ok to still use the microwave?
  • 94 Answers
Probably not. Buy a new one.
Posted on Nov 11, 2014
3 Suggested Answers
  • 338 Answers
SOURCE: A kitchen towel got caught
you would nee to replace the 20amp fuse in it. lwt mw know if you need further assistance
Posted on Nov 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Maytag MMV6178aaq microwave display not working.
Well, assuming your connections are good on the board, and you;re getting about 3VAC on the filament leads (outermost two pins), I'd say you would need a new board assembly.
(The VFD tube is not available separately).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 10, 2009
Is it safe to use an epoxy grout in my Amana RSW458P microwave oven? About an inch of the grout in the bottom back corner, where the bottom meets the side wall, has peeled away.
this must be an oldie cus im not in the knowlege of any microwaves that are sealed with grout , most all today are heat sealed using an ultrasonic weld that i know of
but i caution you using non food grade materials inside any oven, heat generated by cooking may leak out chemicals in sealers and "grout" that are not designed for food and poision the food inside id contact Amana directly and inquire about them selling you a tube of this sealer ?
Sep 09, 2014 | Amana Microwave Ovens
Problem with split light brown mica cover ?
I would bin it. Playing around with microwaves can be LETHAL.
May 08, 2014 | Goodmans GS200 Microwave Oven
Can I still use the microwave if paint is peeling in one corner?
Yes, but it really should be fixed to prevent rust and arcing.
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Apr 22, 2013 | Sanyo Microwave Ovens
SMH1622B 1.6 cu. ft. Over-the-Range Microwave (Black) how do I remove the cover
there should be screws around the back and at the front corners at the bottom then it should pull off
Mar 03, 2013 | Samsung SMH7178STD Microwave Oven
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
I just found a hole in the back corner of a microwave oven that I've been using for over 2 years without any problems. Can this be repaired?
Jun 27, 2009 | GE Microwave Ovens
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
