Question about Sony Audio Players & Recorders
What's the power supply needed to run a sony pslx 10
Voltage needed to run it
  • Sony Master
  • 5,151 Answers
Fortunately for you somebody on a forum did rebuild this turntable to working order, without the rest of the system. This is what they wrote:
"A 2x10 V 10Watt transformer to the wires ( white connected to the center tap ) and the TT came to life. The TT doesn't contain a preamp but the cartridge is connected to the small PCB covered by a metal shield ( you can put RCA connectors in the back like I did )."
Posted on Sep 03, 2015
I want to know how to check ballistic voltage on a dip tv
    How to test TV Powersupply Review - YouTube
    ? 5:19
    https://www.youtube.com/watch?v=TELvc0thP34
    Nov 8, 2011 - Uploaded by Tampatec
    powersupply Common problems & solutions to fix TV power issues, How to test troubleshoot Sony power supply repair help ...PLS I WANNA THE MANUAL FOR SONY CRT TV MANUAL FOR MODEL .... I can do is check everything out on they power board. an you tell me how to do this on everything?Missing: ballistic ‎dip
    Notes on the Troubleshooting and Repair of Television Sets
    www.repairfaq.org/sam/tvfaq.htm
    Nov 17, 2009 - Low voltage power supply fundamentals; Standby power supplies; Typical TV ..... For more info or if you want to buy one, see DLP TV Showcase." ... is a good chance of repair without access to specialized test equipment and parts. ...... If the bulb lights at full brightness, you know there is still a major fault.
    Dell W5001C 50" plasma fix - Instructables
    www.instructables.com/id/Dell-W5001C-50quot-plasma-fix/
    InstructablesMy buddy's Dell 50" W5001C plasma television conked out one day so I set out trying to fix it. ... Make sure the first thing you do is measure the voltage on the Va test point... I know this is a really old post, but i found a dell 4201c on the trash the other .... I can't or don't want to pay to fix, I may be off to Best Buy for a new TV.Missing: ballistic
    Amazon.com: NEW BALLISTIC PERFORMANCE LITHIUM ...
    www.amazon.com/BALLISTIC.../B005KLOYHE
    Amazon.com, Inc.
    Rating: 3.3 - ‎23 reviews
    NEW BALLISTIC PERFORMANCE LITHIUM EVO2 12V 12 CELL ..... false codes to your bike during the starting process since its voltage will dip in and out.
    ELI5:How do digital devices know how much energy is left in ...
    https://www.reddit.com/.../eli5how_do_digital_devices_know_ho...
    RedditNov 16, 2013 - Want to join? .... ExplainedELI5:How do digital devices know how much energy is left in their batteries? ... A digital device will take this voltage and will look up how much ..... I had a cable tv installer who put little caps on the end of a few .....Electronics such as lithium drill batteries and other battery items test ...
    Do modern TV's (LCD/LED) really need a Voltage Stabilizer ...
    https://www.quora.com/Do-modern-TVs-LCD-LED-really-need-a-V... QuoraThis causes temporary power dips to other electronics, like the LED TV, which in turn affects the TV's processes. In fact, one of the reasons why many LED TVs ...Missing: ballistic
    The First Lunar Landing
    https://www.hq.nasa.gov/alsj/a11/a11.landing.html
    NASAJan 5, 2016 - However, it is often desirable for the engineers to know what the residuals were before .... [Armstrong - "We did landmark checking to check our position over the ground, and that ..... [That is, Houston wants Eagle to use the aft omni-directional antenna.] ... I'm getting a little fluctuation in the AC voltage now.
    Power Rectifiers
    www.myerspowerproducts.com/index.php?option=com...id...
    Medium Voltage AC Power Solutions ... Low Voltage Switchgear ... Low VoltageSwitchboards, Panelboards & Meter Boards · Low Voltage ... Cable Television.
    Searches related to I want to know how to check ballistic voltage on a dip tv
    tv power supply repair
    tv power supply diagram
    tv power supply symptoms
    power supply for sony bravia tv
    tv power supply repair kits
    tv power supply repair cost
    sony tv power supply board
    sony tv power supply problems
    1 2 3 4 5 6 7 8 9 10 Next
Feb 09, 2016 | Televison & Video
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
What's your problem?
Problem in the power supply. Check connections around voltage regulator ic, will be mounted to a heat sink marked with str or strz or mxaoi. Check for bad connections in power supply, Voltage reg ic is very common to go out in Sony's.
Nov 11, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
Hello ,my germ guardian 5A54A265 ultra sonic humidifier is 110 volts from what i read on it ,i moved to Germany with my husband ,and here the voltage is 220 volts ,my Question is can i plug it in the...
You need to use a transformer and it needs to be capable of supplying enough power to operate your humidifier. There should be a plate on the humidifier that shows it's requirements in Voltage and either AMPS or WATTS. The transformer needs to be able to supply approx 20% more Amps or Watts, at least, than your humidifier uses. It's ok if it can supply a lot more than this but not if it supplies the bare amount required or less. The transformer will show this as Output in either WATTS or AMPS.
As some appliances quote AMPS and others quote WATTS you may need to convert between amps and watts this is how you do it.
WATTS = VOLTAGE multiplied by AMPS. and
AMPS = WATTS divided by VOLTAGE.
Also note Kw stands for Kilowatts or thousands of watts.
The voltage you're drawing is 110 so that's the figure you use.
Apr 17, 2011 | Health & Beauty
Monitor LCD of my sony vaio VGN CS 13 G/Q laptop is running blank. The monitor LCD light does not perform appropriately (its light is off. I can not read the monitor's LCD so I must add/connect external...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Sony Computers & Internet
I NEED TO KNOW HOW MANY AMPS YOU NEED TO SUPPLY TO RUN A 600WATT AMPLIFIER CORRECTLY? AND ANY SUGGESTIONS ON WHAT I SHOULD USE TO POWER IN IN A HOUSE?
if you have an old pc you can use the power supply to power your amp in house make sure it is +12v 10-16 amps be carefull make sure your voltages a correct with a vom
Apr 18, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
20-Volt DC Power Supply instead of 12-Volt amp
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Jul 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
176 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
