Question about Samsung CLP-650N Laser Printer
No display Its been in storage for a couple of years. Ive had it connected to the power for 24 hrs, any suggestions about how to get it going again
  • 63 Answers
Turn it off completely, disconnect power cable.... Reconnect printer power cable directly to the power board after that turn in ON ...
Thanks
Posted on Nov 12, 2014
My garmin nuvi 1390LMT will not power on...any suggestions
After a couple of years without use, the batteries may be completely dead and take all the Chargers current and not power up.
Jan 21, 2015 | Garmin Nuvi 1390LMT GPS Receiver
Wi- fi
I would say you have a problem with the router unless you are not reading the situation correctly, the other alleged connections will not be accessible for any reason unless you are the one paying for that connection, it would be illegal otherwise, so i am going to assume that you have a faulty router.
Jun 22, 2014 | Acer C7 Chromebook
My pro 39 scanner loses memory after unplugged for 24 hrs..Question: is there a memory storage battery inside unit..
Here's a link to your radio's manual. Make sure the rechargeable batteries are able to accept a full charge. If they have been recharged more than a couple of hundred times, they may need to be replaced.
Pay attention to which jacks your are powering the radio through. The PWR and CHG jacks perform some similar, but very different functions.
The AC or DC adapter can be connected to the CHG jack when you wish listen to the radio (and recharge at the same time) ONLY when NiCad batteries are installed (or to simply recharge the NiCad batteries with the radio off). Recharging with the radio off will allow the batteries to recharge fastest (10 - 18 hrs).
As per the manual, you should not connect a power source to the CHG jack if using anything other than NiCad batteries in the radio, as they will heat up and could explode, instead connect to the PWR jack whenever using regular, non-rechargeable batteries.
Jul 26, 2012 | Radio Communications
Will I decrease the life span of my lap top if I leave the monitor on 24 hrs a day???
I would suggest you to turn the power button on the monitor off when then computer is not in use as you do not need display if you are not working.
Electrical equipment has a life on all of its electronic components inside which will decrease the life if its left on for 24hrs. Monitors of these days comes with sleep facilty which disables the monitors motherboard but the power supply has a constant current which is again an electronic device.
Final answer to you qustion would be to keep the monitor turned off when not in use.
Nov 10, 2010 | Computers & Internet
Error 1203 printer not working
Here is what I found about the 1203 error in the dell community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Jun 16, 2009 | Dell 946 All-In-One InkJet Printer
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No Power
your themal fuse needs replacing. you access the fuse by unsrewing the control panel then then removing the plastic cover that protects the power supply board. the fuse is the white piece that's located on your power supply board that has 2 wires connected to it. a black wire and a black wire with a white stipe.
May 20, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Initial Setup flashing on and off
1) Do a hard reset = leave unplugged for 12-24 hrs , then
try again.......................................
2) What does "until the remote is disabled" mean ??
Nov 09, 2007 | Sony KV-32V16 TV
Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Nov 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung CLP-650N Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
