Question about Saeco Primea Ring Espresso Machine
Bought a second hand saeco primea ring & when i filled with water & milk,i switched it on and message says "insert tank-milk cleaning cycle". its all quiet & then next message saya"restart
Bought a second hand saeco primea ring & when i filled with water & milk,i switched it on and message says "insert tank-milk cleaning cycle". its all quiet & then next message saya"restart to solving the problem". i restart and starts all over again same messages.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Give it back
Posted on Dec 11, 2014
cutejessie
  • 72 Answers
SOURCE: Water tank empty
the sensor is not working.. try to identify the sensor inside the tank and change it..
Posted on Dec 29, 2007
  • 74 Answers
SOURCE: Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Posted on Jul 11, 2008
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
  • 1089 Answers
SOURCE: Saeco professional. Water tank needs filling, switch OK
Hi
It could be the magnet in the water tank. If it sinks you will get that message. How do you know the switch is OK?
Posted on May 22, 2009
SOURCE: primea ring - milk not hot
I had the same problem and my retailer worked it out for me when you select say cappuccino and go to the coffee quantity then the milk hold down the button that looks like a jug for over 2 seconds then the milk temperature comes up and you can adjust to low med or high now i am finally enjoying a hot drink
Posted on Oct 19, 2009
NEED TO GET OUT OF THE DESCALING PROCESS. HOW CAN I DO THAT?
Descaling instructions:
  1. Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
  2. The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
  3. Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
  4. Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
  5. Place a bowl underneath the milk carafe dispenser and the dispensing spout.
  6. Pull out the milk carafe dispenser to the right up to the " " icon.
  7. Press the " " button to start the descaling cycle.
  8. The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
Sep 28, 2016 | Coffee Makers & Espresso Machines
Close milk drawer message stays on at all times
Look inside the machine where the milk tray goes into. You will find plastic lever where the milk tray push in when you close the tray. Check the switch by pushing in with finger and see the message gone off?
**** a small plastic hose and saddle on the milk tray in a place where it touches the switch lever then close the tray which should contact the lever harder.
Jul 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
My Saeco Primea Cappuccino has stopped dispensing milk but no error is displayed
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
Apr 16, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Touch
If you use the milk feature, please make sure that you rinse after making a milk drink or the machine will automatically request a milk cleaning cycle which is different than a rinse. For example if you make a milk drink and you skip the rinse cycle and leave the machine without rinsing for more than 20 minutes it will schedule a mandatory milk cleaning cycle.
It is okay to skip milk rinsing if you are making drink after drink as long as you rinse after the last cup.
Hope this helps you out.
Saeco's First Authorized Service Center of New York
Cerini Coffee Services
www.CeriniCoffee.com
Oct 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea RIng - Cycle interrupted - only a few drops come out
Hi
Have you found a solution yet?....we have the exact same problem....
Mar 16, 2008 | Kitchen Ranges
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring Espresso Machine Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
