My umc tv model 69/63g-3g-gb-3b-ftcu keeps saying do not power off scan but doesnt do anything and will not cone on I believe it may be a firmware update I need but can not find where to get this from any help would be great, Matt
  • 3 Answers
I think your problem is more hardware related, I had a similar problem and here is what I did, Googled the service number. They will referred you to a qualified repair tech. He will come out and diagnose your component. Order he parts and come back. But I will tell you that it is probably a documented problem and its more cost effective for the manufacturer to replace complete electronic board sections. So ultimately thats what the repair tech. will be sent to do. Hope this helps!
Posted on Nov 11, 2014
2 Suggested Answers
gopakumarg43
  • 74383 Answers
SOURCE: TV UMC SCAN
Please provide more details. What do you want to know? Gopakumar Gopalan Google
Posted on May 12, 2014
How do I fix my e- motion 39 l.c.d. tv
press "AV" & find out the current input/source is set.
Oct 09, 2015 | Televison & Video
Hi, Can any one please shed any light on my problem, When I switch the tv on it says DO NOT POWER OFF and under that SCAN it scans upto 100% then scans again upto 100% and again and again does not stop...
Try a hard reset by unplugging the tv while it is turned on. Then push and hold the power button for a few minutes to drain the electronics and memory of all. Then release button and replug back into outlet and then turn on to see if that has done the trick. If that does not work you can contact tech services for a hidden code to restore unit to factory defaults.
Sep 09, 2017 | Televison & Video
CAN I GET NETFLIX ON MY FREEVIEW TV.
If the has an spare HDMI port, you could purchase a Google Chrome Cast. Use it with your WIFI and a Android device to access Netflix.
May 22, 2014 | Televison & Video
TV UMC SCAN
May 12, 2014 | LG 42LC2D 42 in. LCD HDTV
46/188g-gb-5b-ftcu-uk umc tv just keeps saying scanning it goes from 0% to 100% then starts all over again ???? also it is upside down ????? any help would be great
It sounds that the main system memory IC to this set is faulty. Check and replace it. It is a very small IC, having 8 solder terminals, can be located very near to main system control IC. Contact any service technician. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 09, 2013 | LG 42LC2D 42 in. LCD HDTV
Stuck on scan
It may be that the power cut was the result of a power surge. It may be that the outage has caused damage to the components of
your tv.If it does not return to normal you will need to get a very GOOD technician to diagnose the fault. It may be that the tv can be repaired, it may not ...but eirher way I would think about seeing whether the power company is liable for the damage.
The fault is almost certainly something that needs to be checked out by a pro
Aug 20, 2013 | Televison & Video
My UMC tv keeps comen up scan and gets to 100% and then start all over again help please
Hi Ziggy. Firmware issue on your main AV board my friend. I have heard of this with UMCs before.
You could try a factory reset. If that doesn't work, you could try updating the firmware with a usb flash drive - you would have to find the firmware for your particular model from the manufacturer's website (assuming they have one).
If that doesn't work:
Obviously, if it is under warranty contact the seller or the manufacturer and they should sort it out for you.
If it is out of warranty then you could try replacing your AV board. Spare parts from TVs damaged in transit or used parts are often listed on eBay and other specialist TV parts websites.
You would have to open the back - remember to UNPLUG IT FIRST - and you're looking for the big circuit board that has all the video inputs in. Find the part number on it and search it on eBay or a site like www.flattvparts.co.uk - replace the board and (assuming they sent you a working board) that should solve your issue.
Jun 18, 2013 | Televison & Video
How do i get an update for iphone 3g 4.5 firmware doesnt let me download anything
You need to backup you iphone 3G on iTunes first.Then Restore the phone on itunes itself.It will automatically look for the update itself and install it.
Mar 18, 2013 | Apple iPhone 3G
Hi I've recently bought a UMC 40" TV (model: M40/74G-GB-FTCU-UK) and everytime I try to tune it, it just says there is no signal and no channels are found. Everything is connected as it should be....
strange it sounds like there could be more of an issue with the skybox but if you have any RCA cables plug them in and use AV1 or AUX on the tv set however if it has HDMI then plug in a HDMI cable to and from the skybox otherwise check on the back of the skybox and see if there's a channel the TV must be set to
Aug 22, 2017 | Televison & Video
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Electro Med Services...
