Question about Sewing Machines
I just got a handheld sewing machine it has refused to make stitches whilst sewing I have tried and tried no stitches. Pls is there anything am not doing right
I just got and it was making stitches before and then suddenly I stopped I even went on u tube to check a few things that probably I iam not doing right but there is nothing.
  • 1,147 Answers
With ANY machine you have to have thread on a bobbin coming from the underside of the cloth. Did you check the bobbin to make sure there's thread on it?
Posted on Nov 11, 2014
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
SOURCE: My sewing machine will not stitch, it is threaded right
how do you crrect the timing on a yamata 811
Posted on Dec 20, 2010
Singer 4530- stitch length adjustment not working. How do I fix?
Since you indicated the machine has been cleaned and lubed, that is probably not the problem unless the stitch length lever is sticky or the feed dogs are hanging up somewhere. Suggest perhaps directing heated air from a handheld hair dryer into the internal mechanics (focus on the stitch selector lever and the feed dog mechanics) and see if that loosens anything.
Apr 04, 2016 | Singer Sewing Machines
I CAN NOT GET THE SEWING MACHINE FEED TO MOVE WHILE I TRY TO SEW?? WHAT WOULD BE THE PROBLEM??
the control for forward and reverse is close to the neutral position
Mar 15, 2016 | Sewing Machines
Will not sew decorative stitches
Hi Anonymous, Either it's a bottom end machine with no variations in stitches possible or the selector mechanism is shot. If it's the latter then I think that you need specialist help to sort it out whether by reinstalling the software or replacing the selector mechanism.
Jul 12, 2015 | Singer Sewing Machines
My handheld machine won't sew any fabric.the thread just flaps in and out of the fabric but its not sewing the fabric
Sounds like it is not catching the bobbin thread which is how it makes a stitch. Try re-threading top and bottom threads. Or perhaps your tension is far too loose. Adjust tension higher or lower to test.
Oct 18, 2014 | Singer Sew Quick - Handheld Sewing and...
Refuses to sew on thick fabric why?
Here's a pdf of your manual Singer owns White's manuals now.
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Typically you need a longer stitch to sew thicker fabrics, have you tried that yet?
Dec 13, 2012 | White Sewing 979
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
Oct 23, 2012 | Janome Sewing Machines
When I turned my machine on after a couple of days of rest, it seems to have developed amnesia. It no longer knows how to do any of the stretch stitches. It stubbornly refuses to do anything but straight...
Like all computer things it might be for ever wondered about but do this... UNPLUG the machine from the wall outlet and let it sit for 20 minutes. When you replug it, it should be fine.
Jan 08, 2010 | Singer 7462 Mechanical Sewing Machine
Machine will not zigzag
The guy is right, dust kills the moving parts. try oiling the shaft that holds the needle up about 1/2 way and then run on straight stitch with no thread to work in oil, do this several times till you feel that it runs smoothly and you have a little movement side to side as this is necessary for your zig-zag. if that does not work it may be a cam or belt in the top part that needs replacing and you will need the repair to tell you that. I asked them to give me a quote before any work was done so I knew what I was up against. I love my machine so it was worth the 200.00 to get the parts replaced. It will sew anything cause it is a older model with metal rather than plastic parts. hope this helps good luck
Jun 17, 2017 | Singer 3116 Simple
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
