Question about Music
I need a user manual for a Gallien-Krueger 212LC guitar amplifier from 1981 era
User Manual vintage for six string guitar. I need a user manual.
  • 6 Answers
SOURCE: Guitar strings on a mandolin.
By now you may have solved this problem, but maybe this information is still helpful:
What you are essentially recreating is a tenor guitar. Many companies make tenor guitar strings. I would suggest D'Addario J66 80/20 Bronze Tenor Guitar Strings (10-32). I've done this a few times and it is quite fun and makes for an interesting travel guitar.
Have a blast!
Posted on Jan 09, 2009
  • 161 Answers
SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Posted on Mar 23, 2009
  • 1138 Answers
SOURCE: need instruction manual for a Fender 15g combo
Here is the page you need:http://www.fender.com/support/amplifier_schematics.php Look under hard copy archives if you can't find it in the newer section. I emailed them at cosumerrelations@fender.com for a manual and schematics for a Fender Sidekick 10 and they emailed me one right away and were really nice. Please let me know if this helps.
Posted on Nov 20, 2009
  • 5603 Answers
SOURCE: need owners manual for line 6 spider 3 stereo
Try this site:
http://www.scribd.com/doc/5573363/Line6-Spider3-Guitar-Amp-Manual
Posted on Jun 02, 2010
  • 5603 Answers
SOURCE: diagrama del circuito Gallien-Krueger 800RB
Download here:
http://elektrotanya.com/gallien-krueger_800rb_sm.pdf/download.html
Posted on Nov 16, 2010
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Where is V193037
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
I just bought an 800RB (been WANTING one for DECADES, finally put "cash-on-hand" together with "the SWEET one came along"). I want to know if the speaker jacks for the 300-watt amp are...
Here is the schematic AND everything you need to know about the speakers:
Scroll down to "Get Manual" on the site and click on it to download. It appears that the MINIMUM impedance on the trebel upper set is 8 ohms and MINIMU on the woofer is 4 ohms at the jack in each case.
Apr 26, 2011 | GallienKrueger Gallien Krueger 800rb
I have a Gallien Krueger Backline 600 head rigged to a GK Blackloine 410 BLX-II cab. There is a crackle sound emitting from all the speakers, so I'm guessing there is something wrong with the head. Have...
i) If the crackle is there with all input signal cables removed, then likely to be the head.
ii) Does the crackle vary noisily with control settings? If so, move noisy control to & fro about 10 times to wipe any dirt from internals (temporary solution).
iii) If ii) is not a problem, then tap head casing to check whether a dry solder joint or poor internal connection is the cause. Was unit dropped?
iv) If none of the above, then suspect possible component breakdown.
Jan 24, 2011 | GallienKrueger Gallien Krueger Backline...
Marshall jvm 410h i'm getting loads of feedback when i use od1 or od2 orange or red mode
Dampen the strings of your guitar. If feedback disappears, then you need to move the amp so it can't resonate the strings of the guitar. OD1 and OD2 WORSEN the chances of the feedback into the strings. When this occurs you can often see the strings vibrating without the player picking them.
Nov 22, 2010 | Marshall Amplification Marshall JVM Guitar...
I would like to buy and convert a Gallien Krueger 800RB bass head from 110Vac to 240Vac operation. Do the new ones have multi tap primary windings at the transformers that can be converted to accept...
GK does have a version that runs under 240Vac, but it may not be available in the US. I would check with GK directly. Also, an option would be to use a tramsformer for this unit. These are available for around $50 or so for the power requirements of the GK unit. This would allow you to use the amp at either 240 or 110 without the need to change anything inside which would void any warranty.
Dan
Nov 02, 2010 | GallienKrueger Gallien Krueger 800rb
MY GALLIEN KRUEGER 800RB TURNS OFF
If you drive it too hard or block airflow, it may be protecting itself against overheating by turning off.
Sep 16, 2010 | GallienKrueger Gallien Krueger 800rb
My 800-rb won't power up.Nothing lights up...checked fuse and its ok.
Starting point is to open the unit and verify first that the +/- 60 volt power supplies and the +/- 85 volt supplies are producing.
Next check the +/- 15 volt regulators.
You will likely find one or more of these supplies are defective.
Cause could be blown parts or cracks in circuitboard or bad wiring.
Jul 12, 2010 | GallienKrueger Gallien Krueger 800rb
Music Logo
124 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
